Old 07-16-2005, 08:29 AM
nero nero is offline
Rep: 112 Posts: 624
Orbital Sander Advice
When sanding epoxy, what is the best sander type to use?
I have a Metabo/Ridgid 6 inch variable speed sander. It works well.
Would a 7 inch air powered sander cut faster or use less sandpaper? It is lighter in weight.
What are the pro's using?
Thanks
Old 07-16-2005, 11:41 AM
zember311 zember311 is offline
Rep: 10 Posts: 16
I use air powered at the marina. 6 inch ,3 inch and a 4 inch jitter bug, but funny enough my friend is a rep for Metabo tools and I was able to mess around with them.
I.M.H.O it's all the same.
your not going to save that much more paper by going from the 6 to the 7.
Old 07-16-2005, 10:43 PM
Rep: 112 Posts: 624
I dug out my father old jitterbug today. It vibrates less than my random orbital and works better for sanding edges. Gets cold in the hand and has a bit of condensation after several minutes of use.
My best solution is to get better at glassing.
thanks for the advice
Old 07-17-2005, 01:09 AM
Rep: 10 Posts: 16
One ( old head ) as he liked to be called told me something many moons ago.
He said ,
" do you know what the difference between a beginner and a professional is? "
Seeing how I did not have the answer, I stated the simple reply , " No",
" professionals are nothing more then the beginners, only they have already made the same mistakes and have learned how not to make them again "
He was a cool cat,
Still with your mention above, the coldness in the palms is a god sent durning the summer months. lol
they will have to pry my cold lifeless fingers from my jitterbug, they work so well with wet sanding also, just keep it oiled inside and out and you can knock your wet sanding down oh so much.
Enjoy~
Old 07-17-2005, 08:46 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Check this out for a no sand finish... http://www.pbase.com/dr_dichro/electric_boat
Steve
Old 07-17-2005, 11:31 PM
Rep: 112 Posts: 624
Interesting, the thought of using plexiglass and and clamps passed thru my mind also.
On seams, where 2 layers of bi-axel overlap, I am using peel ply and a scrap piece of plywood with 2 or three cement blocks on top. This flattens out the joint. The result is not as perfect as the plexiglass solution.
For the large bulkhead area, I have been wetting out the fabric and pulling excess resin with a piece of weather stripping. Then as soon as the resin gets thick, I pour on one more glass of resin and skim/screet (flow coat). The result needs sanding but not a lot.
Thanks
Composite ocean row boat advice OceanRowSolo Fiberglass and Composite Boat Building 7 01-26-2005 09:53 AM
fibreglassing work advice solcatbrothers Sailboats 3 11-25-2004 08:39 PM
Best sander yet!! Fastredblur Materials 6 08-13-2004 11:03 AM
Advice for Teak Rubrail Replacement. Herb Morrison Fiberglass and Composite Boat Building 6 01-22-2004 09:11 AM
Advice Wanted Re Production Boatbuilding VIKING Boatbuilding 0 06-23-2003 05:06 AM
