Old 01-06-2010, 09:41 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Opinion: cockpit sole resting/secured to integral fuel tanks
Hey guys,
This is not ment to be a thread that discusses the merits or difficiencies of integral fuel tanks.
The boat is a smaller class sportfisher/comercial skiff type of boat it is diesel powered and the fuel tanks will be in a built in saddle configutation.
My questions is what are your opinions pros and cons of built in composite tanks with the cockpit sole resting on top of the tanks ?
Versus a raised deck shelf and additional longitudal stringers a little taller than the tanks inner long wall and deck awthartship beams that are completely seperate from the structure of the fuel tanks, used to support the cockpit sole versus incorperating deck supports glassed to the tanks and fish boxes boxes also built into the sides and bottom of the hull.
Thanks much for you answers
Old 01-06-2010, 09:47 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
My only concern is that you would like an inspection hatch somewhere in the top. If you can live with that, then why not?
Old 01-06-2010, 10:01 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
Integral tank would be sides being the longitudinal stringers and and the top the cockpit sole.. No need to separate them..
Old 01-07-2010, 08:57 AM
Rep: 67 Posts: 243
Thanks guys that ofcourse is easier, my concern was for inspection purposes or if for some reason a repair was required to either the cockpit sole or a tank it would mean cutting every thing out.
Replacing/Redesigning Cockpit Sole AuxiliaryComms Fiberglass and Composite Boat Building 4 10-21-2008 02:39 PM
integral fuel tanks - construction pescaloco Fiberglass and Composite Boat Building 10 03-10-2007 08:41 AM
The Dreaded cockpit sole Dilema!!! grady Fiberglass and Composite Boat Building 11 11-27-2006 08:46 AM
removal of molded cockpit sole from a viking 40 brewersgold@com Boatbuilding 14 07-12-2006 08:53 PM
Cockpit Sole above Waterline height? Seafarer24 Sailboats 8 06-25-2006 12:48 PM
