Old 01-08-2005, 08:58 PM
Fishtale
Oops--Removing Polyester resin Wax
Sorry, I hit the enter key too soon!!
Hi,
I posted here a while back about catalyzing a 30 year old resin and members were quite helpful. I ordered MEK, Co and wax from a glass company in chicago and the floor came out great. I now have to remove the wax coating and I sanded it with medium grit sandpaper but it still seems slippery. I ordered marine vinyl and Ad-vanced Marine Adhesive (390 AD-Hesive) from Cabelas to cover the coated wood. i was curious if anyone recommends a solvent (acetone or styrene?) wipe for the wax removal in addition to the sanding before I apply the adhesive. I'd hate to get a bad bond so I'd like to do it right and only once. Thanks in advance for any help.
FT
Old 01-09-2005, 10:20 PM
tja tja is offline
Rep: 11 Posts: 125
tja
Wipe it down with acetone. Then resand with 80 grit and wipe down with acetone.
Old 01-09-2005, 11:20 PM
FishTales FishTales is offline
Rep: 10 Posts: 6
Thanks TJA. Will do.
FT
Old 01-10-2005, 06:38 AM
Rep: 700 Posts: 3,207
Most waxes are easily taken off with mere hot water and machine dish washing soap.
The active ingrediant is 5% TSP Tri sodium phosphate.
Many areas the tree huggers have had this removed from hardware stores , but the ladies lobby has far more clout , so it stays on sale for automatic dish washers.
A good scrub of this with HOT water and a scotch brite pad (many grades for floor buffers , use the agressive one) works fine.
FAST FRED
Old 01-10-2005, 10:26 PM
Rep: 10 Posts: 6
Thanks Fast Fred. Makes sense that hot water and surfactant would take care of the wax. Will try it out.
FT
Absorbtion of Polyester resin by carbon uni Doc Martin Fiberglass and Composite Boat Building 11 04-18-2005 02:29 PM
Removing polyester Dresin wax Fishtale Fiberglass and Composite Boat Building 0 01-08-2005 08:51 PM
Polyester Resin Floor Coating FishTales Materials 4 09-26-2004 10:45 PM
how much resin? Lew Morris Materials 3 06-22-2004 07:13 AM
Is Vacuum bagging suited to GRP/ polyester resin layups ? VIKING Fiberglass and Composite Boat Building 6 05-07-2004 11:00 AM
