Old 02-17-2007, 08:22 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
off trailer & on to cradle ??
hello, looking for some advise. need to remove a 27ft deep v hard chaine hull from a trailer and install on a wooden cradle, there will be no chance of overhead lifting, it will have to be floor jacks and wood. the good news is that the hull is bare no decks, or cap, weights maybee 1,500 lbs.
any advise, I have a limited amount of time for the transfere, so I want to have my ducks in a row............thanks
mark
Old 02-17-2007, 02:08 PM
Rep: 3125 Posts: 9,399
Call your big friends over for a boat lift/BBQ and free beer. Provide the beer after the lift.
Old 02-18-2007, 03:37 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Bubba-power
Old 02-18-2007, 08:40 AM
Rep: 67 Posts: 243
boat lift
thanks, it all came together faster than i thought it would, a trailer came available yesterday. 4 guys 2 floor jacks ,wood blocks and couple hours, done !!...............and yeah your right beer AFTER not during.
mark
Old 02-18-2007, 08:57 AM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
Well done.
Every time I thought about it, all I could think of was the table cloth trick. You know, where you whip the trailer out so fast the boat would stay still.
But then I realised the guys putting the cradle under would have to be so fast that perhaps it wasn't the brightest idea.
Glad you managed without my input.
Old 02-19-2007, 07:32 AM
Rep: 67 Posts: 243
off the trailer
that would be cool.............heck of lot faster.............and less stressfull !!!!! at least if it fell it would all be over in seconds
we had block and rejack the boat about 10 times and it was 40 inches off the ground. the final lift/drop off the trailer left me under the front of the hull to lower the boat with a very touchey floor jack to lower it with, I was really glad when it was all over.
now the fun begins, got a boat build
mark
Old 02-19-2007, 07:54 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Very glad this is all done and no broken legs
I used to dump my big power boat off on to the lawn some times to use the 4 wheel trailer for something else.
Simple really just pull out the winch wire and take it right arount the bottom back roller and up to the front eye of the bow. Winching then just winched it off the trailer.
Putting back was as easy-- just offer up the trailer and connect the winch wire to the bow eye and winch away, however you must allow the trailer to go high in the air it will come down again as the weight comes on.
Old 02-22-2007, 07:44 AM
Rep: 67 Posts: 243
winching
thanks jack, that sounds like good way to do it
mark
Cradle to support the mold? tiger1047 Open Discussion: All Things Boats & Boating 0 01-25-2007 09:00 AM
Trailer Sailor LP Sailboats 6 12-16-2006 05:41 PM
how to build a cradle for a tri hull boat bigbearfireman Fiberglass and Composite Boat Building 1 03-20-2006 08:22 PM
Trailer wiring penguin82 Boat Design 10 06-04-2004 08:47 PM
Trailer Sailor Pete Rayner Boatbuilding 13 02-27-2004 02:41 PM
