| This is an odd question but I need an answer Ok I have a fiberglass mast and sail off of a windboard. I am planning on fixing the mast onto a flat bottom aluminum boat (also I am going to build outriggers out of some metal pipeing for the cross bars and most likely large PVC pipe for the pontoons. I feel I am more then capable of doing this as i have already done so with my canoe. Althought that was not very safe and we almost flipped it a few times. Now my question is on the mast it is made of fiberglass (made by bic) but does not have any paint or coating on it. I also know that you can get fiberglass splinters from it as I already did. Nothing large just little dust size pieces the mast is not cracked or damaged in any way. I am wonding if it would be alright to use common walmart spray pant to seal it or should I use some specialty sealer on it. Many thanks |
| I assume that the mast is fairly smooth despite the small 'splinters', so maybe a bit of a roughen up with 100 grit paper for a surface coating to hold on to may be in order. The spray paints are usually a bit cheap and nasty and fall off pretty quickly - I have had better success for less cost by getting a small can of quality gloss house paint, make a sort of long narrow bath out of something cheap (aluminium foil) and tip the paint over the mast and let it 'drip dry' - that way you get a smooth finish like spraying. If you have to buy the PVC pipe to make outriggers, you may find it cheaper to get a sheet of marine ply, do a triangular prism shape with stitch and glue out of three shaped panels, and get a lot more flotation for a lot less money. I have found the PVC pipe cracks and breaks easily on impact, wears out in UV exposure unless it has a fibreglass coating, so the plywood method usually produces a much more satisfactory and cost effective answer. You could also use bits out of the same sheet of plywood to make the crossbeams if you are a bit of a woodworker , but steel or aluminium pipe would be fine too. Have fun |
| 2 years Ive tried to answer this question. | Frosty | Surface Drives | 38 | 07-12-2007 08:41 AM |
| Stupid Question-Really Stupid Answer | timgoz | Open Discussion: All Things Boats & Boating | 81 | 06-03-2007 12:58 AM |
| An Odd Viking Request | JeffNeal12 | Wooden Boat Building and Restoration | 9 | 03-14-2007 12:02 PM |
| An odd question from an ex-sailor about boat design | Reb Bacchus | Boat Design | 41 | 04-15-2006 09:09 AM |
| Measuring odd shapes, | duluthboats | Press Releases | 2 | 08-11-2004 04:45 PM |
