Old 08-31-2010, 05:16 AM
Votum Votum is offline
Rep: 10 Posts: 13
About finished with the design.
Been reading more on foam, XPS (extruded polystyrene) which is the blue foam insulation you get at home depot, is incredibly strong It's also very water resistant and easily sandable.
I am going to put the entire thing together out of 5 panels, which will have holes drilled into all of the support areas and wooden dowels glued into the holes to hold the foam together.
After its together I will cut the "hatch" out of the foam, and make some sort of hinge for it, also trim out some channels so I can lay weatherstripping into the glassed one.
Now I think I am getting from you guys that elmers wood glue is a suitable barrier to put on the xps to enable me to use Polyester resin, right?
I'll end up doing a test first to see how thick I need to lay the glue on it.
Also, is this a stupid idea:
Leaving the foam on the top. The foam will be sanded and shaped, glass will be laid over it, and then I am thinking of laying glass on the inside of the top as well...is this kosher or the dumbest idea ever? Will the foam melt in the sun or degrade over time?
Thanks for being so nice by the way!
Old 08-31-2010, 07:22 AM
Rep: 10 Posts: 13
http://www.rqriley.com/frp-foam.htm
This is exactly what I am going to do
Using XPS though...Man I am excited. Designs are finished, will upload when I get off work!
Old 08-31-2010, 08:25 AM
apex1
Originally Posted by Votum View Post
Water resistance is the least property you need!
Why so complicated? Test the foam by brushing some styrol (thinner) on it. Wait if it disappears or not.
If it does not, you must not "prevent" it.
You cannot leave the foam inside. It is too brittle to stay intact. Vibration will soon make powder of it.
Regards
Richard
Old 08-31-2010, 11:49 AM
Rep: 10 Posts: 13
Here are my completed plans
Old 08-31-2010, 12:09 PM
apex1
Looks nice.
The Latex paint will probably not work! And a screwed layup is sure more costly than getting the right foam and test it!
Old 08-31-2010, 12:42 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
You can get this painted to match auto paint. Or you can get matching aerosol cans at a parts place. Avoid latex and use a good oil based primer.
Hoyt
Old 08-31-2010, 12:44 PM
hoytedow's Avatar
Resistor
And apex is right. It looks nice. Well done and thanks for your service.
Hoyt
Old 08-31-2010, 12:50 PM
Rep: 10 Posts: 13
Thanks guys. I am always looking for tips OK so no latex...I think I am going to spend some time searching for Urethane foam when I get home. Sounds like that is the best option. Do they make it dense enough for my needs? How much does a 4x8 sheet normally cost? The only stuff I can find online is mattress foam
No foam core...what if its urethane? Should I not use any core at all? I'm sorry I'm being such a hassle Trying to get every single detail worked out in my head before I even start buying stuff lol. I will test whatever I get though because I've never done fiber before. Done plenty of bondo so I think the basic idea is the same.
Paint for the outside is going to be krylon camo olive drab
Old 08-31-2010, 12:52 PM
Rep: 10 Posts: 13
Oh and how do those mesaurements look as far as strength goes? I know flat spots reduce strength in fiberglass, I was thinking of doing a layer of 1.5oz mat on top of the foam, then a layer of maybe 15 or 20oz bidirectional cloth, then another layer of mat as the finishing layer. That should be about 1/2" of fiberglass or a little more I think. It doesnt need to support any weight, since the windows will be whatever weather resistant and scratch resistant plastic I can find
  #25
Old 08-31-2010, 01:03 PM
hoytedow's Avatar
Resistor
You will probably need to buttress where I placed the green lines. Otherwise I have no substantive criticism.
Not a boat question :(-buttress.jpg
Hoyt
  #26
Old 08-31-2010, 07:03 PM
apex1
A litttle less is suffficient.
The quality of your layup is important. Half an inch of glass is too much.
A layup as described is far less than that, and sure suficcient.
Richard
Longtail boat question tomac Boatbuilding 3 09-20-2009 05:09 AM
I have a question on the use of a boat? thudpucker Wooden Boat Building and Restoration 9 11-13-2008 09:04 PM
First boat-materials question APA-168 Materials 7 09-09-2008 05:58 PM
jon boat question lloyd Stability 8 06-06-2007 12:46 PM
Wooden boat question One Canadian Boat Design 7 02-03-2006 06:49 PM
