Old 04-20-2006, 09:29 PM
luisjg luisjg is offline
Rep: 10 Posts: 11
non skid deck recomend
will paint the deck but there any idea on how to give it a diamond look fisnish like non skid.
how to do it??
resin?
Old 04-20-2006, 10:47 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
The texture pattern on factory built boats and other surfaces need a mold. You can have an anti slip texture by adding it to the paint or applying it over the paint, which is what I've done. Crushed walnut shells works very well and can be taken off easily, which it's true with sand. There are a number of different types of texture you can add. I suggest applying it over the wet paint method, instead of mixing it in the paint, because keeping the grit even and mixed in the can is tough. Do a search for the subject, there have been many past posts on the subject.
I supose you could tape off a hatched pattern with thin tape about an eighth of an inch wide, but what a pain for a diamond pattern, then apply the texture.
Old 04-20-2006, 10:56 PM
Rep: 10 Posts: 11
its a hard decition,,
i think im going to paint the deck the masking tape to borders the apply some white duraback to the areas i want non skid
Old 04-21-2006, 01:17 PM
JPC JPC is offline
Rep: 20 Posts: 90
I also prefer molded non-skid to grit for most situations (as a bow man, I've sawn through my knees and my clothing many times on foredecks!). You might like treadmaster products, which provide the pattern and are quite easy to install.
See: http://www.tiflex.co.uk/marine/marine.html
Regards,
JPC
non-skid in epoxy resin KMD Fiberglass and Composite Boat Building 14 08-09-2006 08:24 AM
Non-skid addative KMD Fiberglass and Composite Boat Building 15 03-05-2006 09:39 AM
Mold-in Non-Skid Brent Ashman Materials 3 05-11-2005 04:27 PM
anti-skid deck texture Lew Morris Materials 21 07-14-2004 01:30 PM
anti-skid deck texture Lew Morris Boatbuilding 4 08-02-2001 05:02 AM
