Old 01-12-2008, 05:15 AM
JV_Comp JV_Comp is offline
Rep: 10 Posts: 12
non-atomised gelcoater info
I am looking to purchase a new gelcoat spaying system. Does anyone have experience with the non-atomised versions available such as the INDy sytem or others? Which would you recommend?
Old 01-12-2008, 11:30 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Most systems will work, you just need to re-learn the process. At one time they were going to be required, but the Feds backed off on it. Not many accounts use them, many found no advantage in emmissions and it was difficult to keep the gel coaters from messing with the settings and just atomizing the gel coat in a different way. Go with a brand that will supply good support for parts and service. MVP is the dominate player in gel coat and resin spray equipment.
Old 01-12-2008, 05:38 PM
Eagle Boats Eagle Boats is offline
Rep: 16 Posts: 169
I have two Binks gel coat units for sale. One is a single color, and the other is two color.
Old 01-16-2008, 12:44 PM
Rep: 10 Posts: 12
non-atomised gelcoater continued
I have been looking at different external mix gel coat spray systems. Do you know anyhting about Phoenix Equipment Co. products such as the Apollo gelcoat and Atlas wet out systems? Their prices are reasonable. I have a small shop and I would like to keep equipment costs down.
I am primarily concerned about overspray not VOCs. I don't want a cloud of atomised material floating all over the spray booth and complicating clean up, etc. I have observed some operators in well ventilated booths working without face masks. Overspray and bounceback seemed non-existant.
Old 01-16-2008, 09:41 PM
Rep: 288 Posts: 662
I've never used their equipment and it may work fine, but there's a reason MVP has most of the market, it works, you can get parts and they have tech service all over North America. I would look for some used equipment from a mainstream company first.
Old 02-08-2008, 09:55 PM
tja tja is offline
Rep: 11 Posts: 125
tja
Hello, Go with MVP. I have a Magnum mini pro gelcoater I bought new. Works very well. I also have a older Magnum chopper gun with a 20ft boom that kicks ass over a Venus or Glascraft. Good luck.
Old 02-11-2008, 09:29 AM
juiceclark juiceclark is offline
Previous Member
Rep: 71 Posts: 373
we need a gun
We need a gelcoat gun and chopper gun. If it's worth shipping all the way to Fort Myers, FL, can you email me a couple of pics? Thanks!!
Tony Clark
tcclark@comcast.net
Looking for a gelcoater - any advice? Dresca Marketplace 1 05-03-2007 10:57 AM
Looking for used Chopper gun System & Gelcoater cbboatworks Marketplace 16 09-19-2006 08:54 AM
Looking for used Chopper gun System & Gelcoater cbboatworks Marketplace 0 09-04-2006 07:55 PM
Mini Gelcoater System and Chopper Gun vectorsports Marketplace 0 02-13-2006 11:33 AM
need info roland Boatbuilding 2 06-12-2003 02:22 AM
