| Nomex honeycomb core vs Divinycell To All If one were to make, lets say, a 1/4 thick panel. Carbon fiber inner and outer layers. Is there really any big strength and weight advantage using nomex honeycomb core over using infused Divinycell. (both epoxy) It seems to me that if there is only a bit more shear strength and lightness in honeycomb, the complexity of using it is not worth it.(I am thinking aircraft parts here.) Infusion is a one step process. The honeycomb is three and the cost is way up there. Thanks Fred |
| You cannot infuse honeycomb. The resin will fill up all the empty cell of honeycomb. Honeycomb is best in aircraft parts and prepreg fabric. It has an equivalent strength in Divinycell but the shear strength is way too low for boat application. Besides, they don't use honeycomb for the hulls for obvious reason. Cabin sidings maybe usable. |
Thanks |
| Not exactly. In my data, Standard Nomex has 32 kg/m2, 0.36 Mpa shear strength and OX has 29 kg/m2, 0.32 Mpa shear strength comparable to Divinycell H30 which has 38 kg/m2 and 0.35 Mpa shear strength. But using shear specific (more strength per weight) the honeycomb is slightly better than H30. Except that I have not seen honeycomb with higher shear strength. It lacks the shear strength so use is limited to cabinetry and wall division in boats. It cannot take up the dynamic loads imposed on the hull. In aerospace application, weight is important so it is combined with high modulus skin and it works. |
| the 144kg/m3 aramid honeycomb has a shear strength of 3.5Mpa down to the 29kg/m3 with a shear strength of 0.5Mpa... Only prepreg is compatible with honeycomb, and its very expensive... nuff said... |
| I have made a few kayaks with 3mm OX Nomex and wet epoxy resin over 10 years ago and it worked fine , the main issue was to keeping resin webs bonding the core to the skins in a 5.2 metre craft with only 7 or 8 kg to play with. (overall it was a pain and i pursued 2-3mm PVC Foam or 1.5mm Spheretex cores after that) |
I noticed that you have very low shear strength values for balsa. They seem to be only ~60% of these: http://www.gurit.com/files/documents...lexwev1pdf.pdf Why is that? |
| Building with Carbon fiber and nomex honeycomb | Fgayford | Materials | 7 | 12-06-2011 07:48 AM |
| New Honeycomb Core Design | djaytch99 | Boatbuilding | 13 | 08-07-2011 11:56 PM |
| Divinycell vs Core Cell | CatBuilder | Materials | 73 | 01-25-2011 08:48 PM |
| Vacuum Bagging honeycomb core | ian_upton | Fiberglass and Composite Boat Building | 35 | 07-07-2010 03:43 PM |
| Nomex Core | granite | Sailboats | 12 | 03-08-2006 07:19 AM |
