Old 05-20-2008, 09:08 PM
martylee martylee is offline
Rep: 10 Posts: 5
No foam under stringers ???
After making the decission to re power my 23ft Carribean crusader, built by international marine, it came to my attention that when the motor was removed it would be a good idea to replace the stringers and engine mounts, as they were pretty much stuffed. After reading endless threads on this topic, all advice is to put foam under the stringers. The original stringers have no foam under them. So my question is to use or not to use ! Should the stringers be glassed all over and epoxied to floor, then glassed aswell ?
Thnaks for any help or advise.
Old 05-21-2008, 04:57 AM
Boatbuilder BC Boatbuilder BC is offline
Rep: 10 Posts: 9
your original stringers were probably made in a mold and then glued in. The foam used in stringers is mostly non structural and is only used as a former for structural laminate made up of biax and uni-directional layers. using foam would probably be easier as you will something to lay up over with out the need for mold making
Old 05-21-2008, 06:07 AM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
go here,,,it answers every question ya got,,,,,so far,,,,..
1987 Bayliner Transom/Stringer Modification
hehe ,,,,,Jim------>
Old 05-21-2008, 06:21 PM
Rep: 10 Posts: 5
the stringers are all timber, or what is left of them. because they have badly rotted its hard to tell if they were actually connected to the floor or had glass laid over them holding them to the floor.
Old 05-21-2008, 06:24 PM
the1much's Avatar
hippie dreams
it dont matter if they were or not,,,they NEED to be glass from hull, up over,and back to hull.
in fact the last few post on that link deal with that.
Replacing stringers / foam 1980 baja Mdsv16 Boat Design 2 04-27-2008 08:16 PM
stringers shane blower Powerboats 15 04-20-2008 09:23 PM
urethane foam in stringers fishweed Fiberglass and Composite Boat Building 10 08-20-2006 10:32 PM
foam the stringers fishweed Motorsailers 2 08-19-2006 09:11 AM
Wet foam stringers don1113 Materials 4 08-09-2005 05:24 PM
