Old 09-14-2007, 01:16 PM
sbklf sbklf is offline
Rep: 10 Posts: 43
Nida Core question
I am repairing a boat and using Nida Core for the sole. I purchased 25MM with 18oz wet laminated panels for the repair. I was surprised that I was able to peel the skin from the core fairly easily on the smaller scrap pieces I had left over. It looked like the skin was just adheared to the core with an adhesive or two sided tape. I called Nida and they do make a panel that is just adheared together but say I got the wet laminated panels. I will send samples to them for testing. Being a beginner at this I felt the panels with the skin already on would be easier to work with. The original Nida Core material from the boat is indestructible, I expected the same from the new material.
Do boat makers that use Nida Core for soles use the wet laminated panels like the ones I purchased or is there another form of it that gives a stronger bond between the core and the skins?
foam core glassing question pescaloco Fiberglass and Composite Boat Building 13 11-03-2006 10:43 PM
PVC Core Question Marson Fiberglass and Composite Boat Building 4 07-13-2006 12:38 AM
Nida-Core??? RAS1966 Boatbuilding 2 05-28-2006 12:15 AM
nida-core questions donjames Materials 5 11-08-2004 09:24 AM
Nida core Eagle Boats Fiberglass and Composite Boat Building 0 04-23-2004 10:18 PM
