Old 04-17-2009, 11:02 AM
marlin_angler marlin_angler is offline
Newbie Question on delamination
Hello,
I am new at boat repair, specifically the hull. For the first time, I am taking over the maintenance of repair, paint, etc...
I noticed that on small parts of the keel, where the boat rest on the wood blocks used for support, the fiberglass has been cracked, and at some points a "leaf" has separated about a 1/4 of an inch.
I would like to fix this, and my first thought was to "glue it back together", since it was a small part, then bondo, sand and paint.
As you can possibly have already figured out, I have not a clue on this type of repair; but I am definitely willing to learn.
Anyone has any suggestions???
Old 04-17-2009, 12:17 PM
blaze_125 blaze_125 is offline
I see the light!
Rep: 14 Posts: 87
I haven't been around long enough to point you in the right direction, but I can tell you bondo is a no no. Bondo will soak water.
PAR will most likely get in here and tell you the magic mix, that guy is just unbeleivable
If I'm not mistaken, you'll want to replace bondo with a mixture of epoxy and various fillers.
Old 04-17-2009, 12:50 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 933 Posts: 3,638
Hi marlinangler,
I suspect what you're encountering is bits of gelcoat flaking off, not bits of fibreglass. It is quite common for gelcoat to crack at high-stress points. The stuff is just a shiny, brittle outer film of resin- it carries the colour pigment, and in theory keeps water out of the fibreglass laminate itself, but has no structural value.
The actual fibreglass structure will be visible where the gelcoat has flaked off. It might be greenish, brownish or yellowish, slightly translucent, and will probably have a bit of the random texture of chopped-strand mat.
If the cracking does not propogate into the fibreglass itself, the damage is superficial and the repair is easy. It's just a matter of chipping the damaged gelcoat off, and patching it- possibly with fresh gelcoat, but more likely with a heavily thickened epoxy filler. NO BONDO, EVER or you will be doing this again in two months.
If the fibreglass is damaged, the cracks will extend into the laminate, where they will appear whiter and more opaque than the intact fibreglass, and may contain water. If you suspect the laminate itself is damaged, the repair could be much more extensive and time-consuming.
-Matt Marsh-
Old 04-18-2009, 01:57 AM
Rep: 1133 Posts: 4,712
Log onto www.westsystem.com and down load their "user's guide" and other manuals about repair techniques.
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 06:41 AM
Newbie Question Scottlaf Fiberglass and Composite Boat Building 2 11-10-2006 06:37 PM
delamination question sailinaggie Materials 4 08-07-2006 12:54 PM
newbie with a question wolter9 Fiberglass and Composite Boat Building 6 07-01-2006 06:41 PM
Delamination question... ErikG Materials 2 02-05-2003 11:04 AM
