Old 08-25-2006, 04:36 PM
Searay31 Searay31 is offline
Rep: 10 Posts: 12
New project!
Ok folks, im about to start on this beast. Its a 31 sea ray SRV. 1981
First thing i need to do is take the Top Glass section off the stringers
for peek. What is the best way to remove the top Glass off the wood?
I did two small test drills in the stringers, One stringer has a bad spot
The other seemed ok. So while im there in going to make sure they all
are 100%
There is allot of foam In the front area of boat, Will i need to replace it
after the repair is done? If so what is the best product for replacement?
I have all the bottom out and the hull sides are about 70% exposed all around
Is there anything i could do to the inside of the hull BEFORE i recover to improve the boat? I will (on selective days) be fishing in ocean waters
So any tricks for improvement of ride/sound deadening would be great?
Ill take some pics and post them on this thread as i go. Help would be greatly appreciated. First pics coming tomorrow! thxs
Old 08-26-2006, 06:48 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is online now
Provocateur & Raconteur
Rep: 578 Posts: 604
Hi Searay31
You might want to hop over to bateau.com support forums. One of the admins there Shine (Joel) is rebuilding a Aquasport flatback.
http://209.190.4.227/forum/viewtopic.php?t=11294
He's documented the procedure and materials used in detail with photos. They're a great bunch of guys over there and can probably help you out. I think he frequents this forum as well so you might hear from him soon.
Rick
Old 08-26-2006, 02:38 PM
Rep: 10 Posts: 12
Thanks for that suggestion, alot of good info.. Pic's are on hold till the sun shines again!
Could someone explain the best method for taking off the top Glass section
of the stringers? Thanks
What have I done? New Project redkiller71 Fiberglass and Composite Boat Building 4 03-30-2006 09:41 PM
My new project. Baldur Boat Design 4 08-24-2005 03:45 PM
Looking for a project, please help joe Marketplace 2 06-26-2005 09:31 PM
My Project WildCherry Sailboats 17 05-13-2005 09:37 PM
Project help glassr Fiberglass and Composite Boat Building 0 01-10-2005 10:34 PM
