Old 06-26-2009, 09:27 AM
fasteddy106's Avatar
fasteddy106 fasteddy106 is offline
Rep: 171 Posts: 72
You might want to think about a flex drive for a cordless drill and a long drill bit to remove the rot. If you have the space it could simplify removal of the rot. Both tools are available at Home Depot or Lowes. If the rot area is not too large you get structural foam from the site below fairly reasonable....
http://www.uscomposites.com/
Old 06-27-2009, 03:33 AM
Rep: 2891 Posts: 8,798
The bottom line is you need to expose the core, remove what's bad, replace it, then bond the cutout back in place. Sometimes, you have to be fairly inventive to get around things. I've hung upside down inside lockers or hatches to access a tight spot to preform a repair. Welcome to the wonderful world . . .
It wouldn't be hard to use a hook, bent scraper or other device to gouge out the core. Lots of thickened epoxy and a replacement piece of core will get it done. It only has to be pretty on the outside.
repairing or replacing fibreglass floor aprils fool Boat Design 8 04-29-2009 05:19 PM
Repairing floor stringers seagull369 Fiberglass and Composite Boat Building 26 09-15-2008 07:02 PM
Bad Spot in Stringer Dfrenzy Open Discussion: All Things Boats & Boating 41 06-14-2008 06:04 PM
soft spots in fiberglass floor LEASEGUY Fiberglass and Composite Boat Building 13 08-26-2006 10:08 PM
Replacing Soft floor on Flats Boat bronconut Boatbuilding 3 05-22-2006 12:23 AM
