Old 12-15-2009, 01:35 PM
Msalvatore47 Msalvatore47 is offline
Rep: 10 Posts: 6
Need help with sanding
I own a Rigid 6" D.A. random orbital sander....electrical.
question numero uno...
1) Do i need to wet sand my boat? (i'm completely restoring this boat and it has alot of spider cracks)
2)If i do need to can i do so with my currently owned sander?
3)If i buy a pneumatic sander, how big of an air compressor do i need??
Old 12-15-2009, 01:37 PM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 616
Your planning to re-shoot the Jel-coat then?
I would think your 6" DA would be just fine.
K9
Old 12-15-2009, 04:07 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
1. Depends what you going to put on the sanded surface. Check instructions..
2. I'd rather wetsand by hand if the material ain't very hard.. allmost as fast and better quality
3. Big.. atleast double the sander air consumption .
Old 12-15-2009, 07:44 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
The random orbit sander will take you to 220 grit. Be thorough. Follow the R.O. with wet/dry by hand (some will recommend power-wet-sanding but I haven't tried it yet). You may go through 80 grit, 120,180,220,320,400,600. and 1000 grits but the surface you get is worth it. I'd guess about 6-8 sq ft per hour.
Then machine compound. Spider webbing is too deep to remove. You have to live with it or redo the gelcoat.
Old 12-16-2009, 08:54 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Yes you can wetsand with your electric. (you know water and electricity don't mix so be carefull) I use a spray bottle and mist the surface with water use a GFI cord or adapter)
Use velcro backed sandpaper with no holes in it, if your sander has a dust collector try to block the port off. You can actually get some 5 or 6 inch wet paper at a higher quality tool supplier it is usually used for wet stone polishing I use 600 , 800, 1200.
As for an air compressor, if you have the place to use it and plan on more restoration work it will be the best tool investment you ever make. I think a 60 gallon tank is bare min for running air tools. Sanders really eat up a lot of air and you end up overworking the compressor. 80 or 100 gallon tank would be prefered.
Spider cracks have to ground or groved out completely, determine if they are just superficical cracks in the gelcoat or do they go deeper into the glass, either way they need to be removed. For the cracks you will need to use heavy paper and work out to fine like Allen and others have suggested.
Old 03-08-2010, 05:41 PM
Rep: 10 Posts: 6
thanks everyone. man i got myself into a real big hole with this thing and dont know how i'm gonna get it done by april.
Old 03-09-2010, 04:17 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Checking for spider cracks: Mix some ink in water (1:2), and wipe the surface. The ink will creep in the cracks, so they are better visible.
There are also spray cans with a similar mixture in it. (might be easier)
sanding jbowers417 Wooden Boat Building and Restoration 21 09-20-2007 10:03 AM
sanding the corners of parts lalusiva Fiberglass and Composite Boat Building 2 07-29-2007 01:23 PM
sanding epoxy rturbett Fiberglass and Composite Boat Building 16 01-27-2007 07:31 AM
Sanding and fairing signum Fiberglass and Composite Boat Building 2 09-19-2005 01:53 AM
Gelcoat (sanding) Saeed Fiberglass and Composite Boat Building 3 02-16-2005 03:35 PM
