Old 08-27-2006, 05:57 PM
robbieinga robbieinga is offline
Rep: 9 Posts: 5
Need help repairing this Transom
New lurker and poster here. I recently purchased this 14' fiberglass boat and am in the process of starting repairs to the flooring and transom. But I noticed that most transoms are flat across the back making it easier to remove the inside skin to access wood for repairs, however as you can see in the pics I have this box type structure to deal with can I just remove it and eliminate it from the restoration? Does it serve any benefit. If it stayed it too would need to be repaired. Thanks in advance
Robbie
Need help repairing this Transom-transom1.jpg  Need help repairing this Transom-transom2.jpg
Old 08-28-2006, 07:01 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
I'm not 100% sure, but it's probably there to keep the motor from ripping itself off under power. Could be there for floatation, but it wouldnt last too long because of the holes. I'd leave it alone. Work around it.
-Figgy
Imagination is more important than knowledge.
-Einstein
Old 08-28-2006, 10:19 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Robbie
You might want to flip over here to see a couple of similar projects.
http://209.190.4.227/forum/viewtopic.php?t=11294
http://209.190.4.227/forum/viewtopic.php?t=11328
Rick
Repairing a steel hull Jason Crum Open Discussion: All Things Boats & Boating 11 04-21-2009 11:56 PM
Repairing Impacted Foam TaSSie_deVil Fiberglass and Composite Boat Building 0 06-12-2006 04:10 AM
Need help repairing a catamaran de_sail Multihulls 2 04-24-2006 01:05 AM
Repairing a laser the_sphincter Fiberglass and Composite Boat Building 7 01-24-2006 08:14 AM
Repairing dents in aluminum? chad801 Boat Design 4 12-11-2004 01:27 PM
