#31
Depending on it's shape, you usually have to have 2 to 10 degrees draft to it so the finished part can easily pull free of the mold and the mold can come off the plug. If you have to make a multiple piece mold, it becomes more expensive. !,000 parts off a mold is wishful thinking. Keep your plug for awhile, you might ruin a mold and need another or you might want multiple molds for more production. You can always make a mold off a part, but it works best off a plug. Once you've filed for a patent and have 'patent pending' status, you're good to go, it doesn't matter who sees anything. You also have to have around $300,000+ to defend it against any serious challenges. And just because the Patent Office grants you a patent does not in any way mean the patent is valid. |
#32
| EHhhh...Jim.... Not me trying to tell an ol fox something here..... But I clearly recall prior to this.... Water grinding, smoother, and smoother paper, rubbing, til the shoulders are acin', then wax, wax, wax, then some other film stuff, which i do not recall the name of.... ![]() Ok, NOW i see/ saw that that was mentioned further down, zårryzårry.... But what about a flat flanged area for (gluing) vacuum bagging if needed later...? Too many molds are made with too small flanges.... ![]()
__________________ KnutS "it's dark and we're wearing sunglasses" Last edited by Knut Sand : 08-13-2008 at 12:43 PM. Reason: zårry |
#33
| ummmmm,,,,knutterz,,,,,he said the plug was done,,,,,,so why and how do you wet sand the mold before its there?,,,,,,,oh,,well,,,i see/saw, where you saw/see that hehe ![]()
__________________ hehe ,,,,,Jim------> |
#34
| the difference for a mold you want to use 10 times compared to 1,000 times would be the difference between solid glass construction and a cored construction. example: a 1/2 inch solid would last say 10-20 parts and develop stress cracks in corners etc. from the hot-cold cycles. now a 1/2" glass plus 1/2" ply or other core plus another 1/2" glass you have a "rock" that will be 10 times stronger. The chopper gun could be used to alternate roving and save a buck or two. Thats just speaking from personal experience, having made some 12 or so molds in the last 6 years. |
#35
| I have done a little research on a paint for the mold,,,any thoughts. I know that it needs to be painted and wet sanded and painted and wet sanded and painted and wet sanded then waxed,,,,,,,,,,,is this right? |
#36
| i was just asking because i guess ive never had the opportunity to make a mold that was only for a few uses,,,,,,all the ones ive made have always been solid core built to last for eons.,,, but then again most the molds i made were of boats not parts.. you shoot your gel coat on first joe,,,,,then lay-up your glass and everything,,,then pop it off the plug,,, then sand,, wet sand,,buff,,then your release agent ( i use to use the "frekote" system.) ,,,,thats the "quickie" of it. theres alot of little steps in between,,but them are the basics.
#37
| you like chop guns Over? ,,, we found them to be more messy,,more problems,,and in the end cost more to run,,,,,,,,man i wanted that venus to be my answer to hand-lay-up,,hehe ![]()
#38
| no i do not prefer chop. my experience mostly molds for boat hulls cabins etc. Currently in the shop were using the magnum venus internal mix gun, what a cake walk. most of the big parts, hulls and cabins we hand layup with 1 oz mat then 3610 or 2415 and some 1808 depending on application. on the molds we make the plug is made slicker than s**t and then waxed numerous times. then sprayed with tooling gel, usually I spray twice. say first black then green. the first color a different color than the gelcoat you will be applying to your parts, so you can tell of good coverage. cook composites and polymers supplys all the tooling in our factory. |
#39
| Call Scott Pay, he has 24 years experience, located in Ohio but may be able to work something out with shipping the part - 419-289-9739 or 419-651-3997. He owns a company - has a website www.kar-delplastics.com |
| making a mold | georgiahemi | Boat Design | 2 | 10-15-2007 02:48 AM |
| making a mold question | stephendehong | Boatbuilding | 5 | 05-13-2007 07:46 AM |
| Mold making | MDP | Fiberglass and Composite Boat Building | 2 | 03-29-2007 03:33 AM |
| Making a mold from an original | Dnice | Boat Design | 3 | 03-27-2007 08:23 PM |
| Making Mold!? | zeljkomrsic | Fiberglass and Composite Boat Building | 2 | 09-20-2006 05:32 PM |
