Old 02-13-2008, 05:09 AM
stephendehong stephendehong is offline
Rep: 10 Posts: 4
need help of the interior constrcution
I'm working on a 42' power boat inside, and try to use something attach on the wall and frames, somehing like leatheroid to cover, but doesn't work, please see the pictures and if someone can tell me how to work on that?
what material should use?
need help of the interior constrcution-azimut5514.jpg  need help of the interior constrcution-aft-cabin.jpg  need help of the interior constrcution-azimut5553.jpg
Old 02-15-2008, 06:53 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
I believe you are trying to re-install or install vinyl headliner. There are a few good spray products made for that specific use. 3M makes a good spray adhesive. Most auto body supply stores sell it.
Old 02-15-2008, 11:29 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Also the good 3M hook and hook tape stapled (stainless steel staples) to the liner is virtually unremovable. Once they are slammed together, it is a devil of a job to rip them apart. The tension is adjusted by the amount of tape you use. I am not referring to the standard hook and loop tape, there is a heavy duty hook and hook tape, solid little hooks that lock up real good.
interior Semrin Demirel Services & Employment 3 02-24-2007 05:31 PM
interior Semrin Demirel Boat Design 0 02-11-2007 06:30 PM
interior Semrin Demirel Education 0 02-11-2007 06:22 PM
interior Semrin Demirel Sailboats 0 02-11-2007 06:11 PM
Looking for help with interior.... stant1man Powerboats 1 08-05-2005 12:32 PM
