| Need help with fairing compond I have been making major modifications to a 26' John Allmand and have been mixing glass micro-balloons with polyester resin. The home-made mix does not spread as easy as the store bought stuff. Should I switch the type of filler I am using or should I using this mix for the rough fairing and switch to a high build primer for final fairing? If I use the high build primer should I use the Duratec (gray) or something else? Thanks for the help. |
| Use a bit of silica powder to make the microballoons behave. Yoke. |
| Fairing | Smircio | Software | 12 | 12-10-2005 09:14 AM |
| The best fairing method? | Capt. Chris | Fiberglass and Composite Boat Building | 6 | 10-07-2005 06:47 PM |
| Sanding and fairing | signum | Fiberglass and Composite Boat Building | 2 | 09-19-2005 02:53 AM |
| fairing compound | HWL | Fiberglass and Composite Boat Building | 18 | 03-19-2005 02:05 AM |
| Are there new ways of fairing | Boatbuilding | 5 | 03-29-2004 10:19 AM | |
