Old 01-02-2006, 10:34 PM
DANS DANS is offline
Rep: 10 Posts: 2
Need help couple Questions
Hi guys I am new here as ya can tell. I am in the market for a hunting boat I have found a few designs that if altered could give me what I want. So tonight while on watch I altered a coupel to give me the design I'm looking for.
Now her is the questions sorry for dragging out.
1. Can you cover your framing with say canves and then coat it with wax and liqued release so you can pop the bottom shell off after drying ?
2. If so what is best to use to get canves tight fitting so there is no sagging?
3 How many layers should you use for a good sold bottom that can take running in rough weather and in over sand and eel grass flats?
I'm sure I will have many more questions as I begin this project this spring thank you for you help
Old 01-03-2006, 06:22 AM
Rep: 700 Posts: 3,208
"1. Can you cover your framing with say canves and then coat it with wax and liqued release so you can pop the bottom shell off after drying ? "
This may work , but if youre just building ONE boat , why bother?
There are FG rods with mat attached that can be stapled to your frame and then simply glassed over.
The thickness of the layups will be deternined by the amount of structure & stifening you install inside.
You might consider the "stich & glue" methods instead , and just heavily glass over the hull.
FAST FRED
Old 01-03-2006, 05:55 PM
tja tja is offline
Rep: 11 Posts: 125
Tja
What style of hunting boat have you been looking at?
Old 01-05-2006, 04:36 AM
Rep: 10 Posts: 2
I don't know the name it wil be a semi V with the top decked in and a 4x8 cockpit for shooting out of.
I am new as I said so any help will be appriciated this is my first attempt at a boat. Fred with the rods and mat as you say what stops the cloth form saging when you put the resin and on it
Steel Hull Questions KevinT Metal Boat Building 30 02-12-2008 05:13 PM
Rhino Questions CET Software 23 03-19-2006 04:11 AM
newtimer with some questions about design/construction opteek Sailboats 12 11-23-2005 07:22 PM
Sailing garvey questions jim H. Sailboats 1 10-07-2005 03:55 AM
Some Newby Questions Silenti Sailboats 18 07-10-2005 10:12 AM
