Old 07-07-2010, 01:53 AM
hyboats's Avatar
hyboats hyboats is offline
Rep: 10 Posts: 42
My mold all bubbles
Yersterday I released my mold. There are so much bubbles on the surface like much millets. Now what should I do to repair it ?
Gel coat is vinyl then five layers mat with vinyl resin others are polyster resin.
Bruce
Old 07-08-2010, 04:53 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Post some pictures and lets have a looksee at what you are talking about !!!!
Surely what ever the defects are (bubbles ) they must have been visable before you glassed over the gelcoat !! You could have stripped it all off and done it a second time !!
Sounds like the incompatability between two of the products you have used if its all over . NEED PHOTOS !!!
Lets go back a few steps to the stage of waxing the plug ,how many coats of wax? and what else did you use on top of the wax before you applied the gelcoat to the mould or thin gel coat possibly undercured that has caused alligators !!
Even this will have shown up in the first layer of glass !!!
Did you use any PVA release agent ??
If you did how did you put it on and with what ??
How long was the gelcoat on before you started to glass over it ???
Explain the first layer of glass you applied over the gel coat , what was you catalyst ratio or the resin for this skin ? sounds like a slow brew of resin that could have attacked the gel !! but need to see some pictures .
Repairs wont be easy !!!
There is no advantage using vinylester resin to build the mould ,just use all polyester !! Mixing products is not a good idea and can lead to other problems down the track .
Old 07-09-2010, 11:39 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
If by bubbles you porosity, then yes this can happen, it typically is a result of spray technique. Spraying the first pass too thin or too thick can cause it, so can the catalyst type and level.
VE gel coats are more difficult to spray than polyester types and porosity is the most common issue.
Using VE skin coats is very common in both tooling and production, it can yield a more durable, crack, water and heat resistant tool or product.
Old 07-11-2010, 10:19 PM
hyboats's Avatar
Rep: 10 Posts: 42
pictures of the bubbles
Thank you Tunnels the pictures as following.
I washed the male mold with a liquid (also a type of wax which can help releasing ) 6times, then wax 5times. Then painted the mold with vinyl gelcoat two times painting after the first one harden then paint the second time. About 4hours later I laminated with vinyl resin and mat 2% harder.
What materials should I use to make mold ?
Now how to repair it ?
Bruce
Old 07-11-2010, 10:22 PM
old one !
Need to see pictures first !! Then will try to get you through it !!
Do you have product names and product discriptions of everything you used .
Old 07-12-2010, 12:13 AM
hyboats's Avatar
Rep: 10 Posts: 42
pictures
pictures I don't know how to upload it
My mold all bubbles-8522411111111111.jpg  My mold all bubbles-7.jpg  My mold all bubbles-7412588.jpeg_-.jpg
Bruce
Old 07-12-2010, 12:16 AM
hyboats's Avatar
Rep: 10 Posts: 42
Hello pictures
The three pictures are in same area. When I open flash lamp then it looks clear
Bruce
Old 07-12-2010, 12:22 AM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
Man, those look just like the bubbles than are normal in vinyl ester resin. Odd that they show up in the gelcoat against the mold, though--I used to use VE gelcoat and resin all the time, and while they were normal in the resin, I never had them show up in the gelcoat like that.
How large is the mold? I'm afraid you may end up either refinishing it or building another one with polyester (tooling) gelcoat.
Old 07-12-2010, 01:55 AM
old one !
wow thats a new one on me !
In all my 30 years I have never seen anything like that before !
If its all over its got to be a reaction between the gel and what ever was on the mould !! just had a thought what was the weather like when you applied the gelcoat ? what about the air line to you gun if you sprayed did you have a water trap anywhere in the line ? To understand whats happened you need to reproduce everything last detail you did when making the mould to find which bit made it happen . Without a really clear picture or seeing it first hand its all guess work .
How big are the individual bubbles ??
Old 07-12-2010, 02:54 AM
hyboats's Avatar
Rep: 10 Posts: 42
my mold
The mold length is 23ft.
The bubbles are very very small diameter is about 6mils . Mold looks very glossy when I stand front it it looks like a mirror. but only these bubbles
When painting I didn't use water trap
Bruce
Old 07-12-2010, 04:12 AM
old one !
Ok ! ARE the bubbles easy to burst ?
When you burst them is there water inside the bubble ? The compressor tank , when did you last drain it and let all the water out ? Its a good idea to make the drain tap hiss just a very small amount when you are spraying so any water naturaly leaks out. What is the capacity of the compressor cubic feet per minute and any other tanks as well as the one on the compressor its self !
If you are running the supply hose directly from the compressor you need a good ,big ,water separator close to the outlet on the compressor . But if you are using a wall mounted air system it could need a very serious look at ! some really simple basic principles and moisture is a thing of the past ! well almost !!
To repair the mould will depend if the bubbles are actually droplets of water and how deep they actually are !
I have two options but if anyone else has any thoughts step up and add some words of wisdom !!
Old 07-12-2010, 09:38 AM
Rep: 288 Posts: 662
Which type of spray gun did you use, a pressure pot, or an airless system?
Old 02-27-2011, 07:53 AM
horacewimm horacewimm is offline
Rep: 10 Posts: 7
Saw this before once, and that was most definately water in the compressor coming through to the work piece. We have a dryer system fitted on our compressor and dont have this problem. But if you dont have one then this is the likely outcome. Screw compressors without a dryer are even worse at producing moisture in my experience. H
Old 04-07-2011, 02:07 AM
jiggerpro jiggerpro is offline
Rep: 98 Posts: 135
Why would anyone insist on using Vynilester gel coats (tooling or not) if they are prone to bubbling ? if simple cheaper polyester gels can do the job waht are the benefits to taking those risks ??
Old 04-07-2011, 04:51 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Higher Tg, better elongation, better scratch resistance, etc.
If you are blowing water, then polyester gelcoat will look the same. High quality compressed air is vital, especially in higher humidity areas.
On bubbling of vinylester resins: Very probably not the right catalyst / peroxide is used. Try and get a peroxide which does not contain hydrogen peroxide. This causes bubbling / foaming of some vinylester resins.
Also, there are special peroxides for gelcoats, which cause less porosity, and a better cure level (surface quality) in shorter time. (Andonox MEC)
I must admit that one of our best peroxides for infusion (Andonox MCP), giving long geltimes, only a small increase in viscosity up to the point of gelling, a low exotherm, yet a good final cure, has a small amount of H2O2 in it. When mixing with vinylester, you see some foam develop. However, after 2 minutes it is stable again, and with a bit of patience, or better yet, a degass procedure (highly recommended with any resin) the foam is gone.
Another fun story: I was doing a demo at a customer, with an RTM infusion machine. They had compressed air, the compressor was outside. It had a freeze-dryer mounted. Temperature outside was some -5 degrees C.
At a certain point the machine stopped working. Ice had developed around the air cilinder, where the air expanded rapidly. It turned out that the freezedryer stopped working, and wet, but still cold compressed air was driving the machine. As the air expanded, temperature fell below 0 degrees, and the water froze, jamming the cilinder. We managed to get the machine working again, with help of 2 hot air guns heating the master cilinder of the RTM machine.
rent 100-110ft mold for sailing yacht? or someone can build hull from own mold for me gp333 Boat Molds 19 10-05-2009 08:27 AM
trade mold for mold Fiber-Works Boat Molds 2 07-28-2009 01:06 AM
14' kayak mold for sale ( vaccumme bagged mold set ) carboncopy001 Boat Molds 2 02-05-2009 02:03 PM
Dealing with air bubbles in laminate gary1 Fiberglass and Composite Boat Building 5 07-01-2007 12:14 AM
micro bubbles in skincoat JV_Comp Fiberglass and Composite Boat Building 4 04-25-2004 05:01 PM
