Old 02-08-2005, 09:24 PM
beltran22 beltran22 is offline
My first boat, need help
I've completed my first mold for a 22' flats. Naturally my first step is to wax the mold, 2nd step is to spray gelcoat then lay in the fiberglass. My question is how long should I wait after the last coat of gelcoat before I lay in the fiberglass and how many coats of gelcoat is recommended?
Old 02-09-2005, 04:35 PM
Eagle Boats Eagle Boats is offline
Rep: 16 Posts: 169
Make sure you have enough coats of wax before you put the gel coat on. We usually wax the mold at least 6 times before we spray the gel. In addition, we also spray the mold with PVA after we wax, for the first part. This helps break the mold in. In regards to the gel coat, we spray the mold in three passes with a buildup of approximately 6 mils per pass for a total buildup of 18 mils. You can obtain a mil gauge from your gel coat supplier. When you spray the gel coat, alternate between side to side, and up and down. If this is your first time spraying gelcoat, first practice and then practice again on a small piece of waxed formica. You don't want to spray the gel coat too thin, as the styrene will eat through it and cause all sorts of problems, and you don't want to spray it too thick as the gel coat will have a greater tendency to crack.
Old 02-12-2005, 10:47 AM
Ssor Ssor is offline
Rep: 10 Posts: 174
Sounds like my grandmother's advise on how much salt to add, "You want to use enough, but not too much".
Old 02-13-2005, 06:48 AM
Rep: 66 Posts: 640
Beltran22,
Drop an email to PAR, you can find him in the memberslist. From what I've seen of his posts, his reply will be all you need.
Dutch Peter
Old 08-17-2005, 03:05 PM
boat182 boat182 is offline
Registered
Rep: 10 Posts: 30
I am closing my boat company, would you be interested in purchasing the molds or company? Check out our web site and let me know.
Jay
compassboats.com
956-237-8075
Auto engine marinization DIY Marinizing 231 07-01-2010 07:34 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 07:01 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 10:08 AM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 10:13 AM
