Old 10-03-2007, 02:52 PM
gary1 gary1 is offline
Rep: 33 Posts: 157
MS-Polymer vs Methacrylates
Morning Everyone,
I'm just after some opinions on what is considered the stronger of the two adhesive types, the first one is called an MS-polymer as opposed to a Methacrylate type of adhesive. They are both supposed to be water proof, I have never heard of a MS-Polymer before. I will be bonding Alluminium to an epoxy base just wondering which would be the better of the two as both make claims to being a permanent type of adhesive and claim to have structual strength properties. The MS- polymer type just sounds as though it may be a bit easier to work with. Anyhelp on this would be greatly appreciated.
Thank's
Gary
Old 10-03-2007, 04:08 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
I know nothing about the products you have listed.
I have always trusted my own observations over those of strangers and sales people/literature.
Acquire samples of both and test them, whack them, freeze them, heat them in the oven to 150 degrees.
Then when you read a little something, a light may go off and you will be able to read in between the lines, and cut through the fog.
Just my two cents.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 10-04-2007, 04:30 AM
Rep: 33 Posts: 157
Thank's Kach22i,
Appreciate the advice I've heard a bit about the Methacrylate just never heard anything about the MS-Polymer type. The thing is I live in a bit of an isolated area and by the time any samples get to me Iwas hoping to have this stage of my build out of the way as I'm on a bit of a deadline to finish this boat.
Thank's Again
Gary
Old 10-05-2007, 02:31 PM
Jolly Dog Jolly Dog is offline
I use an MS Polymer marketed by Bostic for ahereing tempered glass to frp windshield frames.
There are a few differences between MS Polymers and Methacrylates. First, the MS Polymer does not have the smell that Methacrylates have. Some people have a resperitory sensitivity to methacrylates. Second, MS Polymers are moisture cured. It may take days for a bead to cure. The Methacrylate is a two part adhesive and dependent on its formulation may cure in less than an hour. In all likelyhood the methacrylate may require a special gun to dispense were as the MS Polymer does not. Finally you will note that when cure the MS Polyer has a much higher elongation before failure.
As for your specific application nothing beats testing.
Uhmw Polymer Boat COLD-EH' Materials 7 03-27-2008 10:38 AM
Polymer Mast eddyb Boat Design 4 01-15-2003 10:23 AM
