| mould sealer? All these question guys ! Is it worth puting mould sealer on my plug? Ive only used it once and i didnt think it made much difference. I have had problems before with the duratec sticking to the mould surface - i think it saps up the wax, so i was thinking the sealer may be the way to go for this . Ive pretty much ruled PVA out - im sure I will be corrected though . I just cant see the point of getting a fantastic shine with the wax only to cloud it over with the PVA ? Unless I should be reworking the new mould afterwards ? ![]() |
| I've had problems with just wax on duratec. I use TR 910 and 900 on duratec. No need to get it beyond about 1000 grit on the plug; the mould polishes up dead quick. Al. |
| A mould sealer is your insurance. Get a well proven system that you are comfortable with, and that can be used in your circumstances. Do a test piece to see if the release is what you expect from it. I see Zyvax products used, but also Ferro FS10, even just using their sealer, and putting Meguiar M87 on top. I also see no point in using PVA, but for very bad moulds. I even made a polyester mould from a boat that was sanded with 220 grit. No shine, however...
| yes, i think that is key - a test piece. thanks. |
| Tend to disagree. We've had good luck wiping a thin coat of PVA on our plugs before making molds from them. Side by side tests, PVA released and without, the plugs came out in chunks. -jim lee |
| My biggest problem with mold release is a too good release. If your plugs come out in chunks, something is definately wrong. I do have some suspicions, but that is for another thread.
| Deck hardware screw sealer ? | jimmyjetpack | Materials | 6 | 10-31-2009 09:11 AM |
| Amerlock sealer | Conachair | Metal Boat Building | 0 | 06-20-2009 07:13 AM |
| Impluse heat sealer for thermal urethane | kach22i | Sailboats | 5 | 02-01-2008 04:29 PM |
| RIB - Impluse heat sealer for thermal urethane | kach22i | Boatbuilding | 6 | 10-11-2007 03:41 PM |
| thompson's wood sealer...is that possible?! | oceangboy2000 | Wooden Boat Building and Restoration | 5 | 01-06-2006 10:25 AM |
