Old 04-23-2005, 04:44 PM
Doug Lord
Moldless Styrofoam Dinghy construction
I'd like comments and constructive criticism of the construction shown on these two sites:
http://www.moth.asn.au/building/gwise_concept_moth.html
http://www.ifrizz.de
Old 04-23-2005, 07:30 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Now that's cute, could be a very good method for low-cost rapid prototyping.
I've only used styrofoam with doorskin plywood to make cheap sandwich panels before, but I think the technique has merits in certain applications.
Yokebutt.
Old 04-24-2005, 01:31 AM
casavecchia casavecchia is offline
Rep: 14 Posts: 103
Styrofoam building
Hi Doug,
I have built a couple of small boats in a similar way.
The main drawback is that the stuff is very poor in compression and it is very easy to dint the boat.
Unless you use vacuum, results are not particularly light.
I think is a good method for cheap experiments and expendable small boats.
Marco.
Old 04-24-2005, 08:34 PM
Boatbuilder
Rep: 15 Posts: 545
Yeah, not a good way to make an heirloom piece to pass down through the generations.
Yokebutt.
Naval Architects Dubai chrisalex Services & Employment 25 03-28-2007 08:36 PM
which construction method? mjpetersen68 Boatbuilding 12 09-26-2005 03:48 PM
plug materials... dow Styrofoam? gates Materials 7 06-09-2005 09:47 PM
uncertain of structural matrials in new project donjames Metal Boat Building 9 08-15-2004 01:22 PM
Kitset Dinghy Russ Wooden Boat Building and Restoration 0 03-11-2004 09:12 PM
