Old 01-27-2011, 09:54 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Molded Nonskid: how to refinish with out sanding ?
Hey Guys,
I want to refinish factory molded nonskid decking with out sanding off the non skid.
Can this be done by abrading with cleanser and a scrub brush then rolling a thin coat of Gelcoat or Gelcoat mixed 50/50 with Duratec high gloss clear ?
One of my competitors uses this method and says it works well and does not peel or release. I have some real concerns about trying it on a customers boat.
We detail boats as well as repair them and need an inexpensive way to restore the cosmetics of the nonskid.
Thank you for your comments
Old 01-27-2011, 01:59 PM
Rep: 670 Posts: 2,457
If its a molded gelcoat pattern, For best results you need to put a tooth on the surface...abrade it. These Norton Rapid Strip wheels on a drill or slow speed grinder do a great job . You could also use a wire brush.
After abrading and cleaning with soap and water Ive always painted non skid molded decks with awlgrip products . To get extra non skid friction particles or suger or sand to the final coat of paint that goes over the molded non skid.
Old 01-28-2011, 09:18 AM
Rep: 67 Posts: 243
Thank you for the reply
I was thinking paint except that the primer needed is likely to fill the negative space in the nonskid pattern, thus loosing the profile in the nonskid.
which primer do you like (do you thin it) and do you abrade or go straight to paint
Thank you
Old 01-28-2011, 09:31 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Any gel coat will build up and hide detail more than most primers and on gel coat primers aren't really needed. Gel coat with Duratec will work, but this type of mix tends to yellow sooner than straight gel coat.
Old 01-29-2011, 01:06 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
I spray-painted the whole non-skid deck with white 2C polyurethane 14 years ago.
No special mechanical cleaning, just the pressure cleaner and a rag with acetone, trichlorethylene or MEK. After all these years the paint is still in excellent condition, except in a few spots where ropes have worn the paint.
Old 01-30-2011, 11:00 AM
Rep: 67 Posts: 243
Thank you for your replies
Any other comments are welcome
Old 01-31-2011, 03:46 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Oxalic acid (a powder I mixed into a thin paste) works great for cleaning fiberglass, non skid in particular. It will leave you with a very clean but dull gel coat finish. For my own boat I waxed the non skid like a smooth finish and then hit it with a pressure washer to blast the residue out of the grooves. The non skid pattern was a flattened checkerboard so it lent nicely to this process.
The acid will cut all wax, including where the wash down runoff runs over, so do this first and be prepared to wak the whole thing.
Steve
Old 02-02-2011, 10:07 AM
Rep: 67 Posts: 243
Thanks Keys
Proper prep of molded nonskid deck for refinishing pescaloco Fiberglass and Composite Boat Building 3 01-22-2011 01:11 PM
How to refinish aluminum window frames pescaloco Metal Boat Building 17 03-07-2010 08:48 PM
Repairing Stress Cracks in a Nonskid Textured Surface gjrylands Fiberglass and Composite Boat Building 22 03-15-2009 09:46 AM
Complete Refinish of an 86 Valero....Need Help Please!! nbvelaro Boat Design 2 05-23-2007 09:43 AM
How to reproduce a nonskid pattern jbassion Fiberglass and Composite Boat Building 12 10-08-2006 04:28 AM
