Old 01-26-2009, 10:33 AM
erikhaha erikhaha is offline
Rep: 61 Posts: 33
Mold material
I searched a lot of threads and I couldn't find what I was looking for so here goes:
I want to make a fiberglass deck for the main hull of my homebuilt trimaran. The main hull is 20' LOA with a 2' beam throughout the middle 1/3 with tapered bow & aft sections. The fiberglass deck will be in the shape of a conic section, sliced in two. Dimensions: 12' long, 0 to 24" in width and 0 - 20" in height.
I plan on making a male mold then fiberglassing that, but I can't think of what to make the mold out of. I thought about the 2" pink foam insulation sheets, gluing then together then shaping them, but I am not sure if this would be the easiest.
Any thoughts or suggestions as to what would be an easier material to make this mold out of.
Old 01-26-2009, 11:25 AM
GAVIOTA GAVIOTA is offline
DESIGNER
Rep: 10 Posts: 4
Hi:
Try this and ad 5-6 foam ribs for stability, fast and cheaper than a solid foam,I hope this helps you...Mold material-mold.jpgwww.MyAluminumKayak.com
Old 01-26-2009, 03:54 PM
Rep: 61 Posts: 33
Wow, I never thought of that. Thanks, now I just have to figure out how to bend it into this shape with the dimensions that I need. Any tips?
Old 01-26-2009, 03:55 PM
Rep: 61 Posts: 33
Sorry, delete last post. I just figured it out.
Old 01-26-2009, 06:07 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
" I thought about the 2" pink foam insulation sheets,"
Styrene - Its the stuff that makes fiberglass resin stink, melts styrofoam. IE that pink insulation. Been there, done that, made one heck of a mess when all the core turned to goo on us.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
material help please madmatt Fiberglass and Composite Boat Building 4 12-02-2006 02:33 PM
mold fillet material Dark57 Fiberglass and Composite Boat Building 9 09-11-2006 01:27 PM
Material help Negroo Materials 0 04-03-2006 09:42 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
material bevan Boatbuilding 4 10-15-2004 05:21 AM
