Old 09-23-2010, 09:26 PM
variverrunner's Avatar
variverrunner variverrunner is offline
Rep: 60 Posts: 58
Mold flange thickness
Sneakyb
In planning your mold you might consider setting it up so that you could use Smooth-0n's brush-on silicone bagging material. Check out their website. The result is a highly reuseable vac bag that does not require perimeter tape. Their detail is to terminate the bag edge into a dovetailed routed slot in mold edge.
I am in the process of adding thicker flanges to one of my molds to have enough thickness to route. I'll be smiling if I don t need to chase leaks at the ends and perimeters of my vac bags.
Good luck with your project
Allan
Old 09-25-2010, 04:43 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I would be interested in your experiences with this material. Till so far some of my customers have used reusable silicone bags, but the experience was that the lifespan of the bag, including the labour to make one, does not come in favour to applying a vacuum bag with sealant tape.
Perhaps this is different with awkward shapes.
For polyester products: Make sure you clean your silicone after each demoulding. Styrene crystals may form, making the bag brittle.
For epoxy products: I have managed twice to get a part stuck to a silicone mould. Even using mould release did not prevent that.
For this moment I do not feel that a silicone bag can benefit from the gap between semi-rigid top moulds (RTM Light) and vacuum film. But I believe that in certain areas it can be used economically.
Isolating Keel Bolts at Flange SeaJay Metal Boat Building 24 07-01-2010 03:22 PM
one-off mold/plug construction for small-parts westsail42 Fiberglass and Composite Boat Building 6 09-21-2006 08:13 AM
Plug and mold construction sandman1984 Boatbuilding 3 12-23-2005 07:08 PM
Direct female mold construction... Brant Williams Boat Design 5 02-20-2005 07:19 PM
what's the best way to build CERTER-FLANGE on MOLD?? seamonkey Fiberglass and Composite Boat Building 0 10-02-2004 11:47 AM
