Old 09-08-2006, 01:40 PM
Dark57 Dark57 is offline
Rep: 10 Posts: 8
mold fillet material
For a one shot mold, will latex caulk work for a mold fillet?
I've seen posters mention modeling clay for fillets: Is it a clay that hardens? Is there a particular type of modeling clay to use?
Thanks, Dark.
Old 09-08-2006, 01:54 PM
Toot Toot is offline
Rep: 17 Posts: 274
It is not a hardening clay. I use Kwik-Clay. It's nice because it doesn't stick to your hands quite as badly as generic modeling clay. However, whatever they sell at your typical arts&crafts stores is fine. Just plain clay- a tan or gray block of it wrapped in wax paper. I think I pay like $10 for a pound, though I'm sure it could be cheaper if you shop around.
It comes off the mold and part very easily with an orange-based cleaner, such as "Goo-Gone". This doesn't seem to effect the finish or the wax. After using goo gone, another single coat of wax seems more than adequate for pulling another part.
I have a severely screwed-up mold with a couple of cracks and 2 large holes that had to be drilled in when a part refused to come loose. I just fill in those holes with clay, stick some clay in the cracks, and lay up another piece. It works fine and adds very little time to the mold prep.
As for latex caulk, what kind of resin are you using? You might want to test to make sure that the resin doesn't eat the caulk. I suppose it could work, but I suspect it would be more complicated than using clay.
Are we off-topic yet?
Old 09-08-2006, 02:11 PM
Rep: 10 Posts: 8
Thank you.
Old 09-08-2006, 05:08 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
Take a look at Freeman's website or maybe Chavant.In England we would probably use plasticene or pre-made wax fillets.
Old 09-08-2006, 05:09 PM
Rep: 95 Posts: 462
use fillet wax , its design for patern making and is excellent for rounding corners, it comes in lenghts of 2 feet and is rounded on one side and a right angle to fit into the corner, all u do is press it in place with a balled tool that they will sulply u with its fast and fool proof perfect round corner every time
Old 09-08-2006, 06:26 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Thanks, Dark.
I don't know about latex caulk, I can't see why it wouldn't work. I've used clay from the toy store, a 1# package of 4 different colored sticks just the same size as sticks of margarine for about 97 cents. Roll a chunk between two pieces of your countertop board until you get a 'rope' of an appropriate size maybe 6-12" long and stick that into the corners. Then take an appropriate sized socket from your socket set, put on an extension as a handle, and drag that with some pressure at an angle along the corners to form the clay. Clean off the two excess edges with a putty knife, wax and laminate. No, the clay doesn't harden, just take care spreading the wax. In your other post you mention not using gel coat, and as some one mentioned you will end up with billions and billions of pinholes. Instead of gelcoat, you might try putting a layer of resin in first, just like gelcoat, and let that set up or mostly so, and then go ahead with the rest of your laminations. Sam
Old 09-08-2006, 06:33 PM
Rep: 95 Posts: 462
only problem with caulking is that it will have silacone and silacone will give u fisheyes if you paint
Old 09-08-2006, 08:24 PM
Now I can see why it won't work! Sam
Old 09-09-2006, 12:14 AM
Rep: 95 Posts: 462
another trick ive done in the past is to fill the corners with fairing compound at a 45 and then lay up, when u release the part block the edge with some 40 grit til you get the roundness you want, just as fast as rolling clay and trying to round it off ,even after all that work u will still have to sand
Old 09-11-2006, 01:27 PM
Rep: 17 Posts: 274
The clay doesn't need wax. Wax the mold and then put the clay in.
Instead of a socket, I would recommend wooden tongue depressors. They won't be as harsh against the already-waxed mold.
How to Fillet Corners? S Hondros Boat Design 8 08-29-2006 03:28 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
material bevan Boatbuilding 4 10-15-2004 05:21 AM
Best Material Aquaholic Boatbuilding 1 09-25-2004 06:27 PM
Alternative fillet materials? Ward Boatbuilding 16 09-03-2004 09:40 PM
