Old 01-05-2007, 06:32 AM
Anders Radmark Anders Radmark is offline
Rep: 10 Posts: 9
Moisture readings
Hello out there - I am an amateur and are in a conflict with a prepurcher surveyor in UK. He mentioned no moisture readings at all. Balsacored hull and deck! Also under waterline! Sailing boat 40 feet.
Second opinion surveyors has following report for me(After hot vac treatmentunder waterline):
No 1, Moisture readings with a Sovereign Moisture Meter on A-scale;
Over waterline between 18-19, under waterline 19-20+, deck 16-19.
No 2 Moisture readings with Sovereign electronic moisture meter with a scale 0-25 where the scale equates to approx moisture content ranging from zero to 2% as measured by weight;
Over waterline 15-17, Under waterline 15-20+
No 2 used a different meter which will detect moisture in the balsa core and in 3/4 of the deck area medium to high levels of moisture were measured.
I really should like commentares on this situation.
Is this a wreck in some years and is it too high readings to repair at all. What experiace is out there??
Should an honest and professional surveyor have discussed high readings with me as buyer?
What levels in moisture do you accept as normal for a ship about 25 years old?
Anders
Old 01-05-2007, 08:18 PM
bilgeboy bilgeboy is offline
Rep: 45 Posts: 157
You are no longer an amatuer. You are now an expert in the utility and accuracy of moisture meters.
Congratulations!
Mike
Old 01-05-2007, 09:22 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Never use a surveyor they are dishonest and are usually paid for buy the broker who chooses them carefully- if he doesnt have a regular.
A man that has had a boat or two will know far more than a surveyor.
A surveyor is like a lawer. But worse.
Old 01-06-2007, 12:49 AM
Rep: 10 Posts: 9
Jack and Mike - I am very glad for your trust in my new knoledge!!
YES , I learn a lot about Grp boats by this. I have only have had wooden boats earlier.
And - I also had some questions about what "normal moisture readings" can be acceptable and about the structural function of a boat in this condition.
And Jack - I can agree with you about the brookers choice of surveyor in my case - But - I must also say that I have met at least two onest and very professional surveyors during my "learning".
Anders
moisture content of plywood mcody2005 Fiberglass and Composite Boat Building 0 11-06-2006 08:27 PM
Ultra thin sheet metal as moisture barrier in plastic composite. SeaSpark Boatbuilding 5 06-27-2006 08:18 PM
Moisture content of laminate? RHough Fiberglass and Composite Boat Building 10 12-27-2005 04:43 AM
Timber varieties and moisture content Willallison Materials 36 07-22-2004 07:28 AM
