Old 02-03-2008, 07:14 PM
reddy reddy is offline
Rep: 10 Posts: 2
Mini 6.5
I am considering homebuilding a Mini 6.5.
Materials - What would be an economical light weight combination other than the exotic Epoxy/carbon/kevlar foam combinations
Mold - I have looked at split hull molding to reduce weight in the construction. No need for a deck hull joint. Bulk of the joint is below the water. Could the boat be molded in one piece? Any ideas or thoughts would be appreciated
I have built a Plywood/frp skinned boat in the past. How difficult would it be to vaccuum mold?
Thanks for any suggestions.
Reddy
Old 02-03-2008, 09:31 PM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
Reddy,
you might want to have a look at Dudley Dix' Mini 6.5 which has a radius chine plywood hull.
All the best, Olav GER-1045 ____/)_/)/)___
Old 02-05-2008, 12:59 PM
susho susho is offline
ex-boatbuilder
Rep: 58 Posts: 59
or francois lucas mini cp, water ballasted hard chine mini.
Old 02-05-2008, 02:39 PM
Rep: 10 Posts: 2
Thank you for responses. I am thinking more of a one off FRP hull and FRP/foamdeck and coach house over the plywood designs.
Reddy
Old 03-05-2009, 08:24 AM
dodgy_designer dodgy_designer is offline
Rep: 10 Posts: 2
Hi reddy,
I'm new on this site.Have you started to build your Mini?I'm also interested in sandwich GRP and i'ìm designing the boat in this months.
Old 03-29-2009, 02:36 PM
maxsalgado's Avatar
maxsalgado maxsalgado is offline
Rep: 10 Posts: 17
I am currently building a mini 650, you should talk with my assosiate about a revolutionary contruccion method, if you would like to contact him let me know
http://picasaweb.google.com/lh/photo...eat=directlink
greetings
Old 03-30-2009, 03:58 AM
Rep: 10 Posts: 2
Reply mini 6.50
Hy
I've never seen such type of construction,and I haven't understand the material fo construction.Can you write me some more?
The lines of the hull are very nice!!who is the designer?
Old 03-31-2009, 02:03 AM
maxsalgado's Avatar
Rep: 10 Posts: 17
hi dodgy_designer, this boat is built in fiberglass, the designer is Juan Miguel Garcia de la Huerta from www.astilleronos.cl in Chile, and he invented an patented a breakthrough construction method which combines a lot of experience in wooden stripped plank construction and fiberglass construction, if you would like to contact him you can check his email address in the web page witch I designed myself and unfortunately I haven’t translated to English yet
Greetings from Chile
Max
Invader Mini Pain156 Powerboats 0 05-04-2006 03:49 PM
Mini 12 rwnwt Boat Design 1 02-17-2006 03:24 PM
MINI-Mini CICCIO Sailboats 16 07-03-2005 01:38 PM
Mini Gaff Naked Dave Wooden Boat Building and Restoration 0 06-02-2005 12:16 PM
A new mini nemo Sailboats 5 03-09-2005 09:50 AM
