Old 11-03-2009, 09:45 AM
brokensheer brokensheer is offline
Rep: 14 Posts: 89
min. HG to infuse
I am working on a few small test panels 1fot square and on that is 1'x2' long, what is the min hg needed to infuse? my pump pulls 25hg, , My intent is to work my way up to doing a section 4'x8' consisting of three layers of 2415 stichmat at one time,, Thanks
Old 11-09-2009, 10:19 AM
Rep: 14 Posts: 89
Well I can tell you now 25hg works like a charm!
Old 11-09-2009, 12:59 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
25" Hg vacuum leaves almost 5" Hg of pressure in the bag. This will not prevent a flat panel from infusing, but can be enough to cause problems on more complex shapes.
Old 11-11-2009, 01:25 PM
Rep: 14 Posts: 89
Marshmat, so do I umderstand you in that 30"hg is what I should target?, The pump I have only pulls 26-26hg, ,
can you suggest a pump that will work better? Thanks
Old 11-11-2009, 08:44 PM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
I believe a Robinair 15600 will pull 29" at sea level.
Old 11-12-2009, 07:52 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
My Robinair 15600 pulls 29". I think we're only a couple hundred feet above sea level. Higher vacuum works better on more complex shapes as Marshmat said. Your 26" should be fine for flat panels. Size of the flat panel doesn't matter much it just takes a bit longer to draw down the full layup to 26". I use a vacuum switch to keep my small flat panel projects between 25" and 27". This prevents the higher vacuum from sucking all the resin out of the stack.
Fabrics with stitched on mat don't infuse too well without a flow media.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 11-12-2009, 11:02 AM
Rep: 14 Posts: 89
Thanks More light shed on the project the better!
theoretical displacement hull shape for min drag Padava Software 93 07-22-2009 11:13 PM
Mercruiser 3.0L 1995 stalls after 1 min wmoss Gas Engines 12 08-27-2007 09:44 PM
MisFire above 4000RPM after 20 min Beech2000 Sterndrives 69 07-10-2007 07:47 PM
Buying a boat for ICW and Bahamas run; advise on quality/min spec please kattz Powerboats 2 08-01-2004 11:54 AM
