Old 01-17-2008, 08:07 AM
cuorefocoso cuorefocoso is offline
Rep: 10 Posts: 16
Melting the lead / fitting the bulb shape
Hi
What kind of expierence you guys have in melting the lead? I am trying to make a part of a bulb, approx 100kg. I see it will be not so easy to handle it as a single solid piece in preduction process. But what is divide it in parts - will it join to a even (solid) piece if three separate melts will be poured into a mould? I mean should they stick to each other?
And afterwards, will the epoxy filler stick to lead to have a smooth and nice finish?
All coments are welcome, these about home-made methods specially.
Lead Bulb / Keel Casting JohnMc Sailboats 0 01-13-2008 07:02 PM
Lead Bulb/keel casting JohnMc Marketplace 0 01-13-2008 06:57 PM
Lead Bulb matalag Boatbuilding 7 06-26-2006 12:10 PM
Constraint fitting a fixed shape inside a hull Grant Nelson Boat Design 10 04-21-2006 05:03 PM
Fitting keels eillew Boat Design 0 04-01-2006 01:43 PM
