Old 02-11-2009, 09:47 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
Matching gelcoat color
Any hints for matching gelcoat to a buff/tan/off white color?
Anyone have a favorite repair kit?
Thanks
Old 02-11-2009, 10:32 AM
CML UK Ltd CML UK Ltd is offline
GRP & FRP Plugs Mouldings
Rep: 20 Posts: 29
You can get off white gelcoat. Best thing to do is get a colour swatch from a chandlery and match it to your gelcoat then buy in a small amount through the chandlers. Big resin suppliers often have agents who sell small amounts.
Tommi Buckley
Composite Mouldings Group
Southampton, UK
www.compositemouldings.com
Old 02-11-2009, 01:16 PM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
If you want to buy it, it depends on the amount you need, five gallons is no problem, one gal is a little tougher and more costly, lesser amounts are even tougher and far more costly.
To do it yourself can be tricky, you can get close, but without access to the exact base resin and pigments of the gel coat your trying to match it may not be great.
If you're trying to match another type of product (paint, vinyl, tile, plastic, etc) it can be very difficult to almost impossible to achieve the correct color and look
Old 02-11-2009, 04:19 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
It is very difficult to match gel coat color and whites are the most difficult. Most boatyards have someone who get this job and they will have a supply of white gelcoat and a kit of color pigments to work with. Without access to this, chances are slim unless you are very lucky. Visit you local boatyard and talk to them. That is what I do when necessary.
Tom Lathrop
Old 02-12-2009, 12:19 PM
rturbett's Avatar
Rep: 22 Posts: 139
I've used the little scratch repair kits that come with 5 or 6 coloring agents. I did an "ok" job getting the tan/buff color. I like the idea of getting color cards. I just need to find someone to mix up a gallon for me.
Rob
Diviny matching balsa rturbett Fiberglass and Composite Boat Building 1 10-14-2008 10:34 AM
Help with paint/gelcoat color GoSlow Boat Design 1 08-10-2008 10:27 PM
Matching Mast Sections phillip Metal Boat Building 5 04-22-2005 08:54 PM
Spraying two color of gelcoat goodwrch Fiberglass and Composite Boat Building 4 05-23-2004 01:42 AM
Scanner used to match gelcoat color jbrown15 Materials 0 04-13-2004 12:10 PM
