| Mat/roving vs. DBM Hi, Are the DBM replacements for mat/roving layups of hulls? For example, typical layups of a 30' sportfisher in the 1970s would be a few layers of mat and then 18 or 24 ounce woven roving, mat, roving, etc until desired lamination schedule was met. Currently are the same type of hulls just laid up with a few layers of mat and then layers of DBM1708 to complete? Thanks Andrew |
| I found that it's a good swap depending on where you use it. DBM contains an outer layer of mat so the difference is that you have 2 layers directional fiber or the same fiber woven. The directional layers in DBM gives higher glass-to-resin %. For other parts than the hull it can be better with woven roving, engine bed etc. |
| S-2 glass fiber roving, 5 and 15 pound spools | BillyDoc | Marketplace | 0 | 08-18-2007 05:34 PM |
| CSM and roving | Bluedesign | Boat Design | 1 | 05-21-2007 05:37 AM |
| matt and Woven Roving or ud and bix | hareb | Fiberglass and Composite Boat Building | 5 | 06-07-2006 10:30 PM |
| Roving Woven???? | man5 | Fiberglass and Composite Boat Building | 12 | 04-09-2006 10:23 AM |
| Choice of MAT vs Woven Roving | jfblouin | Fiberglass and Composite Boat Building | 4 | 02-22-2005 08:34 AM |
