| Mat and roven woven? I am rebuilding a 36 ft motorsailer, that had serious deck and cabin problems, I have repaired the decks with Douglas Fir and I am putting epoxy on and then a layer of mat, this is the first time I used epoxy instead of poly resin, it is different to work with, but I like it, if I was using polyester resin I would use mat, r/woven, and mat, for strenght, but I need only to seal the decks and cabin, the structure is strong, the boat is a fiber glass hull and had wood decks and cabin, should I put roven woven and another layer of mat , or is the one layer of mat ok, I am painting the entire boat with Alwgrip, and no I have not repaired the stringers yet, they can wait. Mark |
| If you use mat , make sure its compatible with epoxy. Some mat has a silane coating that will only dissolve with styrene. I would go with poly, epoxy is not worth the money for what you are doing. |
| Roving Woven???? | man5 | Fiberglass and Composite Boat Building | 12 | 04-09-2006 10:23 AM |
| Triaxial versus woven....... | Roly | Fiberglass and Composite Boat Building | 13 | 03-08-2006 03:08 AM |
| Bi-axial vs Woven rowing | TomE | Materials | 2 | 12-22-2005 04:08 AM |
| Choice of MAT vs Woven Roving | jfblouin | Fiberglass and Composite Boat Building | 4 | 02-22-2005 08:34 AM |
| Mat, when is it needed | Unregistered | Materials | 4 | 02-06-2004 02:46 AM |
