| Mast Base/Post Timber Our plans call for a mast post/base made from oregon/douglas fir, just wanted to know if anyone has opinions regarding the suitability of this timber for this application. From what I have found online oregon has a average density of around 420 - 550 kg/m3, the lower figure being New Zealand plantation, which is close to where we are so may be indicative of local supplies, then again maybe not. I guess the crux of the matter is, is a harder timber more suitable? Any suggestions? Many Thanks. |
| Douglas fir is a softwood that has very good strength and stiffness properties. I will specify it for masts if spruce is not available. Spruce is the best for its strength and stiffness along with light weight, and Douglas Fir is a little heavier. With construction like you show in your plans, that post is pretty big. You won't have any trouble with it in Douglas fir. Stick to the plans. I hope that helps. Eric
| How can i calculate forces mast applies on hull at his base? | kistinie | Boat Design | 11 | 04-13-2009 01:21 PM |
| Timber to Aluminum mast? | sctpc | Multihulls | 2 | 08-07-2008 08:27 PM |
| aluminum mast strut vs oak post | rondolphin | Boat Design | 5 | 10-06-2005 12:39 AM |
| transom bracket and mast base | kany_leo | Boatbuilding | 0 | 04-03-2005 01:37 AM |
| Mast base laminate concerns | Craig_Hastie | Fiberglass and Composite Boat Building | 3 | 06-28-2004 10:32 AM |
