Old 12-27-2005, 04:13 PM
cristofa cristofa is offline
Rep: 10 Posts: 81
manual metering pump for epoxy
Does anybody know of a good, simple, reliable manual metering pump suitable for epoxy? I would like to be able to stick the resin and accelerator tails in the kegs, and set it up so pulling one lever dispenses a 100:22 mix.
In due course we'll get a machine, but in the meantime, such a pump would save a lot of time.
Christopher
www.rocat.co.uk
Old 12-28-2005, 10:58 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
I don't know of any generic ones... Gougeon Brothers (makers of West System) have a pretty nice line of mixing pumps in the proper ratios for their resin, 100:25 if I recall correctly. The most basic is a pair of hand pumps like those of hand-soap bottles, sized to fit standard cans of resin and hardner. They've got a few manual and electric gear pumps too.
Old 12-28-2005, 11:18 AM
Rep: 10 Posts: 81
Matt, thanks for that lead ... unfortunately the only Gougeon pump with enough capacity - the '309 High-Capacity Gear Pump' can't be adjusted to the ratio I need.
Christopher
www.rocat.co.uk
Old 12-28-2005, 04:36 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
I never trust a pump use a scale!
Slippery when wet.
www.cheetahcat.com
Old 12-28-2005, 05:07 PM
Rep: 10 Posts: 81
That's what we do at present, but we are measuring out between 1 and 6kg of epoxy, and I find the scales a pain ... I haven't tried one, but surely a simple, ganged calibrated pump would be easier.
Christopher
www.rocat.co.uk
Old 12-28-2005, 05:49 PM
Rep: 84 Posts: 661
Each to his own!
Slippery when wet.
www.cheetahcat.com
Old 12-29-2005, 10:32 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Home made epoxy pumps
Christopher
www.rocat.co.uk
How about a home made balance scale built like a see saw? Adjust the hole in the center until the two buckets in the opposite end balances out to the ratio you wanted to use.
Pumps are good but from my experience, those "buna" O rings in the pump give out without warning.
Old 12-29-2005, 11:05 AM
Rep: 84 Posts: 661
My guys are quick on a scale get it right to the mark Every time, Pumps can never be as accurate ! And right beside the bench is a large cone on a resin pump we pour into after mixing for the pressure fed roller system on the end of a long hose in the lay up room..Acetone flush! But I have a recovery unit for that also !
Slippery when wet.
www.cheetahcat.com
Old 12-29-2005, 04:15 PM
Rep: 10 Posts: 81
An eccentric balance ... that's an intriguing idea. Load a known quantity of resin in to one side, then just pour the hardener in to the other till it balances.
But I would still prefer a system which automatically dispenses the liquids in the right ratio. Given the number of people who have to mix epoxy on a daily basis, I'm rather surprised that there aren't more/any metering dispensers available.
Christopher
www.rocat.co.uk
Heat Pump => Vacuum Pump Inquisitor Boatbuilding 7 11-12-2005 09:29 PM
Bilge Pump Activity Monitor odysseyII Electrical Systems 4 11-11-2005 05:21 AM
12v Bilge pump timer/delayed shut-off...? paularey Sailboats 5 11-04-2005 02:39 PM
Fuel Pump or no? seaARK03 Powerboats 4 10-26-2005 05:18 PM
bilge Pump monitor odyssey11 Marketplace 0 10-24-2005 06:05 AM
