Old 11-25-2011, 04:33 AM
iceboater iceboater is offline
Rep: 113 Posts: 49
Manual gelcoat dispenser.
I am trying to find a source for gelcoat dispenser like the one I have for catalyst on the photo.
It would need to be one or two liters in size. I would appreciate if someone could tell me where I can buy one.
Thanks, Axel
Old 11-25-2011, 07:55 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Not a good picture !! Cant see anything that resembles a dispencer Just a something???? have thrown away better looking rubbish but wasnt a dispencer amongst it !
Making beautiful boats is a passion never a chore !
Old 11-25-2011, 08:48 AM
Rep: 113 Posts: 49
I agree, but I could not rotate it. Here is another one
Old 11-25-2011, 10:03 AM
old one !
That better !! I am suree some one will be able ti identify and help you . Good idea good luck !!
Old 11-25-2011, 12:36 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I have these available, in 50, 100 and 500 ml size. Contact me if you are interested.
I am using them as well, for dispensing epoxy resin, hardener, polyester resin and peroxide. They work extremely well. (unless someone dispenses mixed epoxy resin/hardener, don't ask...). But even then they are easy to take apart and clean out.
Old 11-25-2011, 02:01 PM
Rep: 113 Posts: 49
Thanks Herman.
They need to be one or two liters in size.
Could you special order bigger ones?
Old 11-26-2011, 01:43 AM
Herman's Avatar
Resininfusion.info
No. But the 500 ml would suffuce. It is relatively easy to do 2 or 4 strokes. We very regularly fill 1 liter bottles with resins, and that goes really fast. (a 1 liter bottle of epoxy resin takes 20 seconds or so)
I guess when the diameter of the piston is increased more (to reack 1 or 2 liters), the power needed to move the cilinder will get too large to pump viscous fluids (gelcoat, epoxy).
When visiting composite shows (JEC, Essen or Frankfurt) I do not recall larger dispensers.
What is available as well is a double pump, which dispenses resin (or gelcoat) and peroxide in 1 go. Mixing ratio from 1-5% (adjustable). This takes the error rate down, and speeds up dispensing.
QC/QA manual mmd Boatbuilding 4 08-24-2010 02:03 PM
GL-Poseidon manual ? internetturk Software 0 06-26-2010 03:09 AM
Glas Craft foam dispenser greg7230 Marketplace 0 05-01-2009 10:08 PM
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 10:09 PM
GHS Manual Juanca Software 1 02-03-2004 06:39 PM
