| Male fiberglass mold & finished surface Ok, I have made a male mold that I am going to fiberglass(see attached picture). My question is what is the best way, or tips/tricks that you guys have used to reduce fairing once the part is glassed? I hate sanding. I plan on glassing it with polyester resin, used for surfboards, because I have a lot of it and it is fairly cheap. I also have a lot of chopped-strand mat that will be used. Not sure the weight, but it is approximately 1/16" thick. After 2-3 layers of fiberglass I want to use gelcoat for the finish. I have never made a fiberglass part from a mold before, but I have researched it and I am pretty sure I am going about this the correct way, I just want to minimize the finishing sanding. Thanks |
| If your male mold is fair the surface should be fair. But you are going the have to fair and sand. I would recommend, mirco balloons, "spheres" not talc if you don't like sanding, they sand easier. It looks like a small hull so there would also be a weight saving. Get a mask. For what it is worth. |
| Vacuumed Boat Mold from finished Plug | Breakwater | Fiberglass and Composite Boat Building | 12 | 08-21-2008 02:07 PM |
| Discussion - Vacuumed Boat Mold from finished Plug | Breakwater | Boatbuilding | 3 | 08-19-2008 06:20 PM |
| Non slip surface incorporated into the mold? | Splint | Materials | 4 | 07-30-2007 10:17 AM |
| radiant hoses vs full surface mold heat | allan white | Materials | 2 | 04-02-2007 06:59 PM |
| Fast, cheap, reusable male molds? | Toot | Fiberglass and Composite Boat Building | 1 | 07-25-2006 05:04 PM |
