Old 09-01-2003, 04:19 PM
Daz K Daz K is offline
Rep: 10 Posts: 4
Making Moulds
hello everyone
i need a little advice from people "in the know"
i know this a Boat design forum .. but the reason im here is not to build a boat
im going to attempt to design my own bodykit for my car . using fibreglass . i want to design my own kit .. so i need to do this myself
please forgive me for using a boat forum for my questions
right .. ANY help would be GREATLEY appreciated
i am familair with using small amounts of fibreglass , so i know the basics
what is a mould built from?
what materials are needed?
where can i get these materials?
what tools will i need?
any books i can buy about building moulds?
how difficult is building a mould? am i wasting my time here? lol
any websites/links that may be of use would be great
thanks people
Daz K
Old 09-01-2003, 05:49 PM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
Female molds are usually made from plugs which represent the actual hull surface.
Plugs can be made from wood (often strip planked), plaster over chicken wire, or various types of foam over wood or whatever frameworks.
A material called C-Flex can be used to make a fiberglass surface without use of a mold. This can be used as the hull itself or as a plug. Bill Seeman in New Orleans is the inventor of C-Flex, and Dave SIntes is a major user and expert on it.
Old 09-01-2003, 06:30 PM
Rep: 10 Posts: 4
dont mean to be a pain .. but what exactly is a plug? i dont know all these words lol
any useful sites u can direct me to?
cheers
Old 09-01-2003, 07:01 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
A plug is a male shape over which a female mold is layed up to then prodduce 'male' hulls out of that mold.
One web site: http://www.valsparcomposites.com/mol...troduction.htm
Marine Composites by Eric Greene Associates
http://boatdesign.net/cgi-bin/bdn/jump.pl?ID=216
(has detailed info but also an overview of the female mold, one-off, and vacuum techniques)
A video - "A Step-by-Step Guide to Molding Fiberglass":
http://boatdesign.net/cgi-bin/bdn/jump.pl?ID=2757
Other books:
http://boatdesign.net/Directory/Tech...ng/Composites/
Old 09-01-2003, 07:04 PM
Rep: 10 Posts: 4
awesome mate thats a great help thanks!
anymore suggestions/help wont go a miss
thanks
Old 09-01-2003, 07:07 PM
Jeff's Avatar
Moderator
What size is the biggest part you'll be creating?
Typically you'll create a perfectly smooth and fair plug as CDBarry describes; once it's as perfect as possible you use several coats of was and PVA mold release. Then you apply gel coat and build the mold of fiberglass (the size and number of parts you want to layup in the mold and pull from it depends on the degree of "overbuilding" and reinforcement of the mold, but it has to be solid so it doesn't distort.)
Now for very small parts if you're only producing one or two, you might even get away with using a pourable semi-hard rubber like http://www.smooth-on.com/ - your mileage may vary (I tried it on much too large a part and ended up getting distortion in the final product, but I think for a very small part that you would only produce one or two of, it could be a quick (though somewhat expensive) shortcut.)
Old 09-01-2003, 07:34 PM
Rep: 10 Posts: 4
u have been a great help mate
i can thank u enuf!
cheers
Daz K
Old 02-23-2004, 01:26 PM
Jason Cosler Jason Cosler is offline
Rep: 10 Posts: 6
Jeff,
I'm interested in your experience with the semi-rigid rubber (plastic?) mold. Specifically, type and size of the part, product name, type of distortion (shrink, twist, etc.), durability. I'm guessing distortion may be the main drawback (?).
I'm looking at some alternate mold making schemes for small hulls (< 20' LOA)with an emphasis on reduced labor costs. So one option is casting female molds as opposed to standard lay-up. More costly in materials (?), but a potential savings in labor. For a small hull, the process might utilize a steel cargo container cut in half with plates (i.e. pieces of the cut-up container) placed inside and welded to reduce the volume of the mold, thereby reducing the shrinkage/distortion of the casting material (I assume shrinkage is affected by be overall mass of the cast). I'm thinking the interior would also have welded struts or ribs (think small I-beams) welded onto the plates to help hold the casting material in place. From there it's simple, right? Suspend the plug in the mold and cast around it. The Task line from Smooth-On makes some decent claims with respect to impact resistance, shrinkage, etc., but what kinds of volumes it can be mixed and poured in is a question.
Impossible?
Old 02-23-2004, 01:44 PM
Eisa Hasan Eisa Hasan is offline
Rep: 10 Posts: 8
hi
Hi Daz
u can check http://www.Fibreglast.com/
it might be helpful
Old 03-07-2004, 06:10 AM
spartin spartin is offline
Rep: 10 Posts: 17
i made the molds for factory five racing it was a 5 piece mold and could be vaced to this day 200 parts no problums car was shelby cobra
Old 03-08-2004, 03:17 PM
Rep: 10 Posts: 17
heres the car
Old 03-09-2004, 10:05 PM
Rep: 10 Posts: 6
I sort of know what I'm looking at here. Trying to orient myself by that classic Cobra "grill." Does the mold separate in lateral chunks (i.e. as if it were cut across the car) or does it come apart around the contours of the panels? Lots of questions. What liquid plastic did you use? Did you pour the whole mold first and cut it or pour it in sections? One of the issues I'm trying to sort though is how to keep tight tolerances on a multi-piece mold.
Old 03-10-2004, 06:07 AM
Rep: 10 Posts: 17
heres my e mail leave your phone and i will call to explane in detail to you monomaina@attbi.com
Old 03-10-2004, 06:19 AM
Rep: 10 Posts: 17
heres a pic of the nose
Old 03-10-2004, 06:22 AM
Rep: 10 Posts: 17
lets try this agan
Are we making any real design improvements?? Wardi Sailboats 199 11-04-2008 03:33 AM
18-24' Cabin / Half cabin moulds Louis Boat Molds 0 07-27-2005 04:48 AM
Plug making BillB Fiberglass and Composite Boat Building 1 08-19-2004 09:05 AM
Making a Spar Plane Inexpensively Bob Smalser Boatbuilding 2 08-12-2004 12:19 AM
Moulds required Boat Molds 4 07-23-2004 12:03 PM
