Old 09-09-2005, 07:47 AM
hunter hunter is offline
Rep: 10 Posts: 2
Making Hatches?
Has anyone tried or seen a homemade forward hatch? - the large square hatches in the bow of the boat?
Mine is a tinted translucent fiberglass and the PO cracked it and made a crappy repair. It is for a Hunter sailboat and the shape of the hatch is a trapezoid(sp?). I was thinking about sandwiching some thick plexiglass between some mahogany - the mahogany would act as the perimeter frame which would rest on the deck when closed.
Just wondering if anything like this has been tried.
Thanks!
Old 09-10-2005, 11:16 AM
Rep: 1397 Posts: 7,216
It has for quite a few centuries. Look up any traditional book like "boatbuilding" by Howard Chapelle or "The Common Sense of Yacht Design" by Herreshoff.
Old 09-18-2005, 05:13 PM
jbassion jbassion is offline
Semi-Pro
Rep: 10 Posts: 63
I am also in the process of re-building my front hatch, and with a sim. shape. This is my second attempt. At first look it appears simple, but you will be dealing with compound curves with difficult courners to miter, especially if you want a radius to the wood, and if you want a curved top to match the curve of the deck it gets even more difficult, because now you will have to bend 1/2" plexi. It is a good project and I wish you luck.
Old 08-17-2006, 06:28 AM
djwkd's Avatar
djwkd djwkd is offline
Rep: 51 Posts: 380
m looking at building a hatch for my boat (17' shantyboat)
Old 08-17-2006, 06:58 AM
Semi-Pro
Rep: 10 Posts: 63
Try this
I used teak slats. I stood in the center of the hatch and laminated the teak in place with wax paper between the deak and the hatch. If you want more info let me know.
Old 08-17-2006, 07:39 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
jbassion, that multi laminated mortise & tenon effect looks sweet, well done, nice teknic. Regards from Jeff.
How to design hatches? forestjohnson Fiberglass and Composite Boat Building 7 02-25-2006 04:43 PM
Idiots Guide to mold making? chipppy Fiberglass and Composite Boat Building 1 08-19-2004 09:27 AM
Plug making BillB Fiberglass and Composite Boat Building 1 08-19-2004 09:05 AM
making foils? sigurd Sailboats 4 07-06-2004 07:33 PM
wave making machine asterix Boat Design 2 11-12-2003 06:48 AM
