Old 07-20-2006, 03:04 PM
James Francis James Francis is offline
Rep: 10 Posts: 21
Maintaining Structural integrity
I want to cut in a storgage box (14x17x 9inch depth) for tools, etc on my 22 foot center console ( storage space is at a minimum). I am going to cut into the storage locker in the bow. Since the storage locker and cut will be made in the liner does it matter if I cut the mounting hole running the length of the liner or across the liner? It fits in either direction. Just wondering if someone has some thoughts of how I might be affecting structural integrity of the boat.
Thanks,
Jim
Old 07-20-2006, 04:39 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
It's hard to tell from your description whether the section you describe is structural or not. Could you post some photos? Any details about the boat?
Old 07-20-2006, 04:57 PM
Rep: 10 Posts: 21
I will try to get some photos - the boat is a 22 fiberglass CC hull and liner, the liner is a separatep component made in a mold and attached to the hull with glue and bolts. On the forward deck there is a hatch that opens up as a storage locker with dimensions that are about 36 inches long and 2 feet wide ( all sides of the storage locker are finished and about 3/8 solid glass/WR.) The bottom of the storage locker is about 8 inches from the hull bottom - the sides of the storage locker are about 12 inches from the hull sides and front vertical surface of the locker is about 20 inches from the bow of the boat. Therefore I can cut out the front or the sides to fit this recessed draw/tackle box. Does that help at all?
Jim
Bulkhead: structural or not? Nopollution Boat Design 4 02-21-2006 02:31 PM
Structural Engineering?? Danger Mouse Services & Employment 1 08-18-2005 11:11 AM
Maintaining Traditional Oil Skins and “Tin” Cloth Bob Smalser Materials 4 12-26-2004 02:28 AM
Structural Joints Gone Ballistic Fiberglass and Composite Boat Building 1 03-26-2004 10:21 PM
Structural foam? skypoke Boat Design 7 01-05-2004 06:39 AM
