| Looking for help fixing cracked PWC I've got quite a deal here. The cracks are due to a lack of support in the hull design......with support problem fixed, how would you guys go about repairing this. Gelcoated fiberglass body. If you guys would please, check out my post i made on a PWC forum. I posted pics of the hull and cracks several replies into the thread. http://www.pwctoday.com/showthread.p...653#post762653 Doesn't seem to be too many fiberglass/ gelcoat experts on that forum, and i just wanna make sure I can fix this, and do so properly. Thanks for any help, opinions, or ideas!!! |
| I want to get the repairs, gelcoated, then we were toying with the idea of painting the entire ski after the fiberglass and gelcoat is repaired. I'm hearing different opinions whether or not this is a good idea. |
| I would re-gell its not a big job on something small. Repair by grinding until the cracks are gone, build up the laminate to the same thickness with cloth and mat and epoxy. Spray gel thinned with duratec, then sand and polish |
| Cracked fiberglas | sailortoo | Materials | 10 | 12-05-2005 11:49 PM |
| Fixing lead filled sheet metal keel with internal corrosion | DennisRB | Sailboats | 2 | 08-02-2005 03:01 AM |
| Fixing interior wall panel | raymond | Materials | 0 | 10-09-2004 07:42 AM |
| I cracked my Gel Coat | scarmack | Fiberglass and Composite Boat Building | 4 | 06-08-2004 04:54 PM |
| Fixing a sub-standard commercial-built boat | lockhughes | Boat Design | 3 | 07-10-2002 09:24 AM |
