Old 12-17-2010, 04:33 PM
79Rocket 79Rocket is offline
Looking for a 28' ish Glass outboard trailered boat
Hi all.. I am a noob to this but am very hands on. I am looking for a fibreglass boat pretty well much just popped out of the mold where I can complete the construction myself. I dont want to go down the path of building a mold etc as it is only for a once off build.. That factor as well as I have no experience with boat building.Though I have done lots of research. I am in Western Australia so if there is someone near me that can assist me with this would be appreciated.
Not sure if this is a wise step to make but I have always wanted to build my own boat but starting from scratch with a one off build seems too expensive.
The boat will be a sportfisher/dive boat so please keep this in mind..
Cheers
Rocket.
Old 12-17-2010, 06:26 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
In this market most manufacturers will probably be willing to sell you whatever you want. I would contact the manufacturers of the boats you like and check.
My thought though is that since you want to do this much work on a boat, you could probably find a hull you like and assume you will gut everything. Normally this is a bag idea since the cost benefit isn't there, but for you it might work.
Old 12-18-2010, 09:37 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Like Stumble said, look for a used boat of that size and rebuild it the way you want. If all you really want is the hull, you should be able to find one for very little money or free and it may have some usable parts on it. I see boats like this for free frequently, the reason is the cost of getting it back on the water is normally much more than buying one that works. But if you want something built exactly the way you want it, this is lower cost method of doing it than buying a new hull.
Old 12-19-2010, 04:07 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Check traffic regulations before entering this adventure. 28 ft boats are usually 10 ft wide and quite heavy. The trailer will be 10 m. long, do you really want to drag that along?
1950 ish Century Mahogany Boat for Sale cudashark Marketplace 1 09-27-2010 08:38 AM
I Need info on my boat - 1988 Tempest 28' with twin 3ltrs darrenkieley Powerboats 2 01-01-2010 08:01 AM
Meow-ish lewisboats Boat Design 5 09-17-2009 01:28 PM
Norse-ish Longship Free Pirate Boat Design 21 03-09-2005 01:41 PM
removing cabin on 28' pontoon boat Guest Boatbuilding 2 12-10-2003 01:04 PM
