Old 03-09-2005, 06:34 PM
steveo steveo is offline
Rep: 10 Posts: 5
Lifting a Deck
Hello all
I am currently replacing the deck on my 23' stieger craft cc. I am going to build up the stringers by about 1.5" so the deck will be higher to battle a water draining problem. (put a honda 225 on the boat and it sits low in the water cause of the weight) I will also raise the deck drains so they will be above the waterline. I would like to know if anyone knows what type of wood to use to build up the stringers they will be glassed to the tops of the stringers and sealed completely? Thanks guys
Old 03-09-2005, 07:03 PM
BLueOne BLueOne is offline
Rep: 10 Posts: 9
Stevo ,I would laminate 2 peices of 3/4 marine plywood and i would use epoxy if possible.
Old 03-10-2005, 09:18 AM
Ssor Ssor is offline
Rep: 10 Posts: 174
Steve, Has your existing deck gone bad? or is it just too close to the w/l? From your post I get the impression that you plan to remove the existing decking to expose the stringers and build them up 1 1/2". Will you then lay a new deck or will you reinstall the old deck? Also are the stringers straight or are they crowned? If you only have a need to raise the deck above the w/l then you could do that with pink extruded styrofoam glued to the existing deck, all of the gaps filled with canned urethane foam and sanded flush. Then lay a plywood deck on the foam and glass it down using epoxy. Polyester resin will desolve styrofoam into an unspeakable mess. As to your original question, you live in New Jersey, you should be able to get white oak, black walnut, douglas fir, or pressure treated pine. But weight is already a problem, so I would seek to add as little additional weight as possible.
Deck To Hull Joint VIKING Boatbuilding 16 10-06-2008 08:57 PM
deck construction Busted Knuckle Materials 12 06-26-2006 03:46 PM
New deck for a 1958 14' Thompson Runabout. Sultana Wooden Boat Building and Restoration 3 05-01-2005 10:25 PM
Replacing a deck Guest Wooden Boat Building and Restoration 3 11-07-2003 04:08 PM
Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! dan Boatbuilding 4 09-24-2002 04:48 PM
