Old 02-28-2009, 05:47 AM
marinetrader marinetrader is offline
Leaking Bimini
I have a sunbrella covered top on my trawler that has begun to leak. Waterproofing it is becomming more of a chore these days so I am considering options.
The sunbrella is covering an aluminum half-tower appx. 10x14'.
Several options present themselves:
1 - Replace the existing sunbrella with vinyl
2 - Building a hardtop
3 - Coating the existing sunbrella with resin; that will keep the rain out huh?
Any thoughts on #3?
Thanks
Old 02-28-2009, 01:14 PM
Commuter Boats's Avatar
Commuter Boats Commuter Boats is offline
Commuter Boats
Rep: 97 Posts: 116
Number three should be taken off your option list, resin would make the fabric stiff which would soon fatigue and crack( if you can get the resin to stick), is unlikely that am acceptable appearance could be had.
Old 02-28-2009, 01:42 PM
Rep: 2891 Posts: 8,798
There is a spray on coating that is commonly available in RV supply stores. It's intended for awning protection against UV. It's relatively inexpensive, easy to apply and it extends the life of the fabric considerably. In Alaska you'd only need apply it every few years, just spray it on and let it dry.
Old 02-28-2009, 06:17 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
!0 x 14 isn't big. Why not simply order an acrylic grommeted boat tarp brand new? Is the shape complicated or only a rectangle?
Old 03-15-2009, 05:31 AM
Typhoon Typhoon is offline
Rep: 150 Posts: 125
If you like the look of acrylic, go with Sunbrella Plus next time, it has a urethane coating applied to the inside. Vinyls are not bad but shrink like crazy and crack, negating their waterproofness.
The modern vinyls just don't last as long as the older stuff either, something changed with them, I am not sure what exactly.
Reproofing acrylic canvases is at best a yearly proposition once you start doing it.
Another option is what a friend did on his catamaran, had thin (two layers CSM, one cloth)a sheet of fibreglass laminate made with a gelcoat on one side and simply riveted and sikaflexed it to the existing frame.
Regards, Andrew.
Aluminum boat leaking kati Boat Design 3 10-21-2007 06:45 PM
Fuel Leaking From Power Head dblanton Outboards 29 06-10-2007 09:05 AM
Leaking Minimost Overhaul Canaduke Wooden Boat Building and Restoration 3 04-11-2007 09:59 PM
Bimini Top Installation question 190BR Beech2000 Powerboats 4 02-11-2007 08:40 PM
Encapsulated lead keel leaking mawilliford Sailboats 2 05-01-2004 09:36 AM
