| laying up a foam cored transom greetings fellow glass monkeys, I am about to start to layup a hull from a virgin mold, the N/A called for a foam cored transom H130 PVC core. I have build hatch lids with foam core but nothing I was getting ready to hang a 200hp outboad from. Please give me your thoughts, also someone recomended coosa for the core but I don't think its near what H130 is, Please help, should I use a putty to bed it vacuum bag it??? |
Is Balsa really that bad ?? Post # 8 And leave the core hype! Regards Richard |
| I too am doing a transom for a similar outboard. I think an epoxy laminate of 4 each 1/2 inch marine ply and biax glass and maybe some biax carbon would be pretty strong, and safe, if the install was also beefy ( lots of fillet, overlapping tapes, and gusset work. I am planning to bag and heat the part too. Looking at manufactured skiff transoms I like the 1/4 X 2 1/2 in ss backing plates on the inside of the transom as motor mounts, and the top channel or cap in ss also. |
| Foam cored 20 footer? | JeroenW | Fiberglass and Composite Boat Building | 24 | 03-16-2009 02:19 PM |
| laying glass in winter .. heating questions | northrivergeek | Boatbuilding | 4 | 01-21-2008 06:42 AM |
| laying fiberglass on vertical surfaces/adding fillers | old man | Fiberglass and Composite Boat Building | 11 | 08-20-2007 12:57 AM |
| Good book on foam cored, hand laminated? | Roly | Fiberglass and Composite Boat Building | 4 | 11-17-2006 03:16 PM |
| Transom Replacement Foam vs Marine Ply | MJB | Materials | 3 | 06-14-2006 04:52 PM |
