Old 12-10-2006, 08:01 PM
scb scb is offline
Rep: 10 Posts: 3
Lay-up Schedule
I am looking for a solid and light cored lay-up. What are some proven schedules? Core type, thickness, density, resin type?
How would this work: 1oz skin, 1708(+-45), 3/4" balsa core, 1808(0-90). E-Glass, Iso resin. The largest unsuported area is 18"x96".
Thanks.
Old 12-12-2006, 12:50 PM
sneakyb sneakyb is offline
Rep: 10 Posts: 6
Eric:
Lamination schedules, core specifications, etc. are a function of the length, beam, intended speed and type of service of the vessel. Also, the lamination schedule and corresponding scantlings for some vessels can vary greatly for each individual component of the vessel.
Someone on this site may be able to provide assistance if you specify the size and type of vessel or component that you intend to build.
Alternatively, you could check out David Gerr's "Elements of Boat Strength" and use the scantling rules he provides as a starting point. Regardless, special care (design consideration) needs to be given to the intended speed of the vessel...
Old 12-12-2006, 05:08 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
The example you give is particularly bad because the fibers in the skins run in different directions.
light weight lay up nordvindcrew Fiberglass and Composite Boat Building 22 09-18-2007 08:48 AM
cutting kevlar .... lay-up and vacuum bagging wet-foot Fiberglass and Composite Boat Building 44 02-03-2007 05:36 PM
RTM VS. Hand lay-up Kovaceski Fiberglass and Composite Boat Building 24 12-17-2006 10:34 PM
Laminate Schedule SOB Fiberglass and Composite Boat Building 2 10-03-2004 07:22 PM
Want to make a glass Raceboat...But... what lay up????? RT's Fiberglass and Composite Boat Building 2 06-17-2004 11:10 AM
