  #31
Old 06-06-2008, 09:18 PM
Steve W Steve W is offline
Rep: 315 Posts: 638
Ok,i pretty much agree totally with kaptin-jer except i use the 7" yellow foam roller covers,they have to be the very thin ones,1/8" i think,anything thicker holds way too much paint,you need to resist the urge to cover.The other thing is i use disposable foam brushes,buy a case of them and chuck em when they start to load up and swell.In our shop we mostly spray with Awlcraft but have done a few roll and tip jobs where appropriate,mostly on wood boats and i believe that Roll and tipping is actually faster when you are honest about it and take into account having to mask off everything and cover everything you dont want overspray on which pretty much means every other boat in the shop every time you prime as well as topcoat so we find ourselves covering boats and then uncovering to continue work the next day only to repeat the processover and over.The actual painting is not really slower either.In the last 2 weeks we have sprayed a 26 ft sailboat hull which took 4 hrs for 3 coats for 1 painter and a 55ft schooner which was roll and tipped which took 2 guys 2 hours per coat for 2 coats of dark green.Yes thats more man hours but for a much larger hull and much less time spent in preparation and no equipment to clean up and all the expensive paint went on the boat.
  #32
Old 06-06-2008, 09:30 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
with all that work,,,tell ya boss to get a building just for painting,,,your current condition must get alot of dust in ya work<thats what i would tell my boss,,hehe
hehe ,,,,,Jim------>
  #33
Old 06-06-2008, 09:34 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
Welcome 'board Steve!!
I finally have a fellow believer. I have been fighting the lone fight to educate these guys for the past two years. I have used those rollers too with success, but most of the guys I talk to on this forum are first time painters. The 4" foam hot dog can be bought at H.D. and works great for about 20 min. I tell them to have one in their pocket to change on the fly. The Westwind you see in this thread, and others, is 38' painted with Flag Blue It took me 1.5 hours, alone, to apply one coat, and I think most of that time was climbing scaffolds.
Again, Nice to have you around. Read some of the earlier threads like the Awl grip Challenge, and you will be able to see where we are.
  #34
Old 06-06-2008, 09:37 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
__and just ignore the 1much---
  #35
Old 06-06-2008, 09:56 PM
TripleCrownNC TripleCrownNC is offline
Rep: 27 Posts: 88
I'm on it now, just went back out and finished sanding that (*&^%&$&^ console, wiped down and repainted. Did this in an hour and it looks great. This is the console that I stood over for 6 hours till 2 am last week and it still ran.
  #36
Old 06-06-2008, 10:09 PM
the1much's Avatar
huh? hehe ;)
damned snailers,,hehe
  #37
Old 06-06-2008, 10:17 PM
Rep: 27 Posts: 88
Much, when you gonna try it,,,,,, ya got materials, ,,,,ya got stuff to paint, ya know what it is supposed to look like,,,,,,ya know what rags, cleaner, all that prep stuff,,,,whats holden ya up?
  #38
Old 06-06-2008, 10:25 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
[quote=TripleCrownNC;207012]I'm on it now, QUOTE]
I thought I was going to have to come up there and put a hurt on you. Keep it going now, All that praying to the paint gods finally paid off. Could have been that chicken Much sacrificed
  #39
Old 06-06-2008, 10:42 PM
Rep: 27 Posts: 88
Texas Chicken. Ya know you do have to pay your dues bfore the Gods will allow. Got a little over analytical when I had all that junk in the paint while back. Sent me off in tangets.
  #40
Old 06-07-2008, 09:01 AM
the1much's Avatar
huh? hehe ;)
i'll try when my arm works right,,and longer then 20 minutes at a time hehe
and when i do, do it,,,,someone will find out and i wont be able to tell them,,," nope,,cant do that, never done it before,,,,hehe
  #41
Old 06-07-2008, 08:50 PM
Rep: 27 Posts: 88
What do you guys really think was going on early when all the crap was in the paint???? I am really doing nothing different cept not using 08 to clean prior and using better rags. I really think something was going on with the 08 and the top coat. Sort of also thinking this stuff is not formualated to be reduced less than round 20%, which I was under before. Remember I had dimples showing up in the roller pan and when I dropped some on clean foil.
I was inside a closed garage. Now I am outside under tarps and see very little trash in the paint.
Did the whole boat again today, sweet. Smoken hot out tho..
Cleaned the urethaner brush from yesterday but this morning looked clean but not as soft feeling. Got new.
BTW, the awlgrip tech rep told me to reduce to the consistancy of olive oil. That is very different that what Kapt said, water. I know who was right.
  #42
Old 06-08-2008, 08:35 AM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
The ONLY problem you had was lint from the wrong type roller, and not thinning enough. Remember I told you that tipping was really easy? Now you are seeing what I ment.
Have fun.
Jerry
  #43
Old 06-15-2008, 09:15 PM
Rep: 27 Posts: 88
Guys, really doing well on the paint, in fact bout rapping it up. I put down a 'final' coat and about 4 hours later reached up and smudged about a 50 cent piece size in the paint, it is more dirty hands than a dent in the paint. It was just barely tacky. Can I over reduce some paint and blend in a repair?? Please advise!
  #44
Old 06-16-2008, 08:14 AM
the1much's Avatar
huh? hehe ;)
ya need to wait for it to cure for a couple days,,,tape off that small area,,then dob some paint on it,,,let that cure for a couple days,,(take tape off right after it flash's off) then you'll need to wet sand it and lightly buff A LTTLE,,since you wont be buffing a large area,,you'll need to buff for a minute,,,wait for 2 minutes,,buff for minute,,wait 2,,,and keep an eye on that area,,,,you CAN go to far and make that spot stand out like a free beer sign.,,,,thats what i do when spraying if i mess up ( there was once when i did,,hehe ) but ask Kapt. bout it,,,i dont think snailing is any different when it comes to repairing a spot.
  #45
the1much's Avatar
huh? hehe ;)
ya need to wait for it to cure for a couple days,,,tape off that small area,,then dob some paint on it,,,let that cure for a couple days,,(take tape off right after it flash's off) then you'll need to wet sand it and lightly buff A LITTLE,,since you wont be buffing a large area,,you'll need to buff for a minute,,,wait for 2 minutes,,buff for minute,,wait 2,,,and keep an eye on that area,,,,you CAN go to far and make that spot stand out like a free beer sign.,,,,thats what i do when spraying if i mess up ( there was once when i did,,hehe ) but ask Kapt. bout it,,,i dont think snailing is any different when it comes to repairing a spot.
Comments on late 80's Yamaha's nukejr Outboards 0 09-24-2007 08:22 PM
Need help on sizing cable runs bntii Electrical Systems 5 09-01-2006 05:59 PM
Too soon old, too late smart coop Powerboats 4 06-17-2006 06:22 PM
How to/best way to touch up urethane paint runs…? paularey Fiberglass and Composite Boat Building 6 11-28-2005 05:50 PM
Options for late starter. E-Farmer Education 4 08-04-2005 07:00 AM
